I am at a bit off a loss.
The log does unfortunately not give any conclusive hints as to what the problem might be.
Can you please send me an export of your settings?
You can export them to a file on the General tab.
Please send them to me via DM and not here to make sure your Twitch token does not get leaked.
I apologise that it is such a chore to get it working for you for some reason.
Bug report :
When using condition "If scene has changed" doesn't work if we change it manually in OBS.
It is only taken into account if another macro change it due to actions.
Bug report :
Unfortunately, I am not able to reproduce this issue.
Which version of the plugin are you using?
Can you share the macro which is causing the issue?
Do you have a log file of the issue with verbose logging enabled?
I downloaded the last version of the plugin for testing purpose, and still have the problem.
My OBS version is 30.2.3 (x64).
I've created a brand new macro to test, and still have the problem (even by manually clicking on a scene instead of using my DIY deck).
How can I have the log ? Where ?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
