Enhanced Broadcasting: Does Auto mode allow 8,000 kbps at 1080p, or still capped at 6,000 (TWITCH)?
cedric102
Hi everyone,
quick question about Enhanced Broadcasting with OBS.
If I enable Enhanced Broadcasting and leave everything on Auto, will a 1080p stream use the (unofficial) 8,000 kbps , or is it still limited to 6,000 kbps?
I couldn’t find a clear, official answer anywhere.
Context (in case it matters):
  • Target: 1080p60
  • Encoder: NVENC (H.264)
I’d love to know:
  • Whether Auto can exceed 6,000 kbps at 1080p with Enhanced Broadcasting enabled
  • If this depends on partner/affiliate status, ingest server, or any specific OBS/Twitch setting
  • Links to official docs or staff/dev comments
I really like the 8k bitrate so should i turn the feature on or off if i have prio on the 8k bitrate?
Thanks!
