Face Tracker
Face Tracker 0.9.1
Thank you for this very good plugin norihiro, but I have a somewhat peculiar use case which involves face tracker cropping settings applying to another source in real-time. Or in other words, applying the face tracker cropping to not only the original source with the face, but also another source with or without a face. I need this because I have another source which generates a synchronized mask for the source with the face. This mask source needs to have the same cropping so that it could be stacked on top of the source with the face later on, but not beforehand(because of some limitations I cannot circumnavigate). I know this might be a little too much to ask, but this functionality could also be used to control greenscreen backdrop with the movement of the face.
Awesome plugin! Thanks for putting it together. One question though... On the dock, is there a way to set the "pause" option to be "on" when opening OBS? Currently, after closing and reopening OBS, the "Pause/Resume" button on the dock does not remember it's last state. I'm using a hotkey with my streamdeck, and the pause/resume is the only way to control it with that.
I know one answer is to "disable" the plugin, but I can't re-enable from the streamdeck, only pause/resume.
I'm having trouble getting the plugin to do anything. I'm using 30.2.3 and I tried v.71 and v.72 on both Windows and Mac and the plugin isn't doing anything. No bounding boxes, controls do nothing. No errors in log file. Clean installations. Everything I can think of. I'm using a Media source with the tracking filter.
This is working great for our needs but i have a request/information to ask. Is there a setting, or can there be a setting, to lock the zoom level manually and choose which axis to use. I would love to simply zoom in some and only automatically pan left and right inside the image. honestly there may be another plugin that does this but yours works great for the other camera views i need on our systems there is just one instance that needs to be a bit more "locked down" so it would be great if that was an option. Thanks
I'm having trouble getting Face Tracker to show up in my list of filters. I'm sure it's something super simple that I'm overlooking... but I'm not sure what to check next. Have tried installing the plugin via the .pkg file and the .zip file. Any suggestions? Thanks!
Mac OS 15.4.1
OBS 31.0.3
  • 2025-04-20 22-55-48.txt
If anyone else is having this issue, or one like it, my band-aid that i found for the moment is to set the vertical deadzone to be 10, the camera zooms in and never moved up or down after that, only side to side. I'm not entirely sure if that is the best way of doing things but it did seem to work out well enough for me.
Mac OS 15.4.1
OBS 31.0.3
Solved. I'm not 100% sure what fixed it, but I reinstalled a fresh version of OBS and tried installing this plugin again, and it is working. If I figure out more details, I'll come back and share. Thanks!
I can not get Face Tracker installed in the new OBS 31.1.0 for MacOS Intel, but I can get it installed and working in the very old OBS 27.2.4 for MacOS Intel.
I tried also manually installing it.
Amy ideas?
I was not updating the plugin for a while so that it might not work with OBS 31.
It would take a little time to support the latest OBS.
In the mean while, StreamFX Auto-Framing filter might be an alternative if you have an NVidia GPU.
I'm sorry for the inconvenience.
It's working in OBS 31.1.1 in Windows 10 pro but it’s showing the preview to bright, so I am waiting for the update :0)
iMac 5K (2019) med Intel i9 processor
Thank you for your work
Hello Norihiro!
I am hoping to use your amazing plugin as a part of an art project.
It works very well but crashes OBS after a few hours.
I am looking for solutions that guarantee it staying on and working for at least 5 hours at a time.
I am running OBS Studio 31.1.2 (64 bit) on a Mac Mini running macOS Monterey v12.1, Apple M1 chip.
Is there anything I can do to ensure a longer run time without a crash?
Thank you for your help, and your great plugin!
Subject: Request for Adjustment in FaceTracker Plugin for OBS
Hi norihiro,
I hope you're doing well. I’m reaching out regarding the FaceTracker plugin for OBS that you developed. I really appreciate the functionality it offers, especially the aspect ratio options.
I wanted to request a small adjustment: when using the 9:16 aspect ratio option, the plugin currently crops from the right side of the frame, which causes the webcam feed to shift out of the center. This means that every time I toggle the plugin on and off, I have to manually reposition the camera feed.
Could you please Please modify the plugin so that it crops from the center when the 9:16 aspect ratio is selected? This way, the feed will remain centered and won’t require any adjustments.
Thank you so much for your work on this plugin and for considering this change!
Best regards, -JampierTooN.
norihiro updated Face Tracker with a new update entry:
Face Tracker 0.8.0
This is an experimental release.
Changes in 0.8.0
  • Dropped support of OBS Studio 27, 28, 29. The minimum required version is 30.0. Previous version Face Tracker 0.7.2 won't work with OBS Studio 31.0.
  • Dropped support of Ubuntu 20.04.
  • PTZ
    • The properties "max control" is now only available when "PTZ Type" is set to "through PTZ Controls".
  • Updated dlib version to 19.24.8.
  • Cleaned-up internal code structures.
The new feature...
What an amazing plugin! would it be possible for you or me to add new dlib HOG and CNN models for vehicles? i want to detect Vehicles, Cars and motorbikes for motorsport. i cannot find any models but i would really like to test this.
Any update on whether or not it is or will be possible to make another source track my face?
To be abundantly clear: I want an additional source, an image in this case, to track my face/head movement so it stays above my head.
ChatGPT assumed this was possible when I attempted to use it to figure out how I would accomplish this. It would theoretically work by having your plugin output the coordinates of my face in real time, and let another plugin - like the Move plugin - use those coordinates to move the source in real time.
You can do it with the Move Plugin and the Nvidia Broadcast SDKs. If you have install both, you find a filter called Nvidia AR MOVE
You're a freakin' legend, thank you! I had the Audio tools from Nvidia I didn't even know there was an AR kit.
