Bug Report Graph Gridlines from IPad not visible in Final Output
I am a teacher and use OBS for recording my lectures. I have two elgato hd60pro cards installed, one of which takes in the input of the camera, and the other one takes the input of the IPad. I use an app on the Ipad for making graphs, and the output video doesn't show its gridlines. I have attached two image files, one of which is the screenshot of the input that goes into OBS. In this one, the gridlines are clearly visible. The other image file is the output file, where the gridlines have clearly disappeared.
  • 2019-08-27 11-47-46.txt
For recording, pick one of the presets under simple output mode. You've configured OBS for streaming at a very low bitrate, so the encoder is likely throwing away things it doesn't consider important. You may also want to put the video format back to NV12. Switching encoder to x264 may also help.
