How To Widen Sources Window?
Germaximus
Hi,
I can't seem to shrink the Audio Mixer window while making the Sources window larger. How can I do that? I want the Audio window to be as big as what my Sources currently is and the Sources to be at least half the size of what the Audio Mixer is. Image attached. Thank you.
At the bottom of the mixer dock, click the pair of vertical rectangles just left of the gear icon. That will change the mixers to vertical, which makes the dock narrower (and looks more like traditional mixers). Click again if you want change back to horizontal.
To resize any dock, hover over the boundary between the docks. The mouse cursor should change from a pointer to a resizing cursor (two arrows, pointing left and right) and the border should turn bright. Click and drag the border to size the dock. The active boundary is annoyingly narrow (especially if you have a hand tremor like this old guy), but it's there.
