Bug Report If you get red output from a device, read here
Status
Not open for further replies.
selonianth
00:34:15: Open Broadcaster Software v0.656b - 32bit (´・ω・`)
00:34:15: -------------------------------
00:34:15: CPU Name: AMD FX(tm)-4300 Quad-Core Processor
00:34:15: CPU Speed: 3813MHz
00:34:15: Physical Memory:  1023MB Total, 1023MB Free
00:34:15: stepping id: 0, model 2, family 21, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 4, total cores 2
00:34:15: monitor 1: pos={-1600, 0}, size={1600, 900}
00:34:15: monitor 2: pos={0, 0}, size={1600, 900}
00:34:15: Windows Version: 10.0 Build 10240 (revision 16384)
00:34:15: Aero is Enabled
00:34:15: OBS Modules:
00:34:15: Base Address     Module
00:34:15: 00D20000         OBS.exe
00:34:15: 65A40000         OBSApi.dll
00:34:15: 69870000         DShowPlugin.dll
00:34:15: 67A60000         GraphicsCapture.dll
00:34:15: 67A30000         NoiseGate.dll
00:34:15: 6A3B0000         PSVPlugin.dll
00:34:15: 68610000         scenesw.dll
00:34:15: ------------------------------------------
00:34:15: Adapter 1
00:34:15:   Video Adapter: NVIDIA GeForce GT 620
00:34:15:   Video Adapter Dedicated Video Memory: 1020850176
00:34:15:   Video Adapter Shared System Memory: 3220975616
00:34:15:   Video Adapter Output 1: pos={0, 0}, size={1600, 900}, attached=true
00:34:15:   Video Adapter Output 2: pos={-1600, 0}, size={1600, 900}, attached=true
00:34:15: =====Stream Start: 2015-10-17, 00:34:15===============================================
00:34:15:   Multithreaded optimizations: On
00:34:15:   Base resolution: 1600x900
00:34:15:   Output resolution: 1064x600
00:34:15: Loading up D3D10 on NVIDIA GeForce GT 620 (Adapter 1)...
00:34:16: ------------------------------------------
00:34:16: Audio Format: 48000 Hz
00:34:16: Audio Channels: 2 Ch
00:34:16: Playback device {0.0.0.00000000}.{120d9a1f-e05e-4b3b-a79f-8210edf3c2ad}
00:34:16: Using desktop audio input: Speakers (Turtle Beach P12)
00:34:16: Global Audio time adjust: 0
00:34:16: Using auxilary audio input: Microphone (Turtle Beach P12)
00:34:16: Mic time offset: 0
00:34:16: Audio Encoding: AAC
00:34:16:     bitrate: 80
00:34:16:     device: Full HD 1080p Web Camera,
00:34:16:     device id \\?\usb#vid_2084&pid_0805&mi_00#6&18e5bba7&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
00:34:16:     chosen type: YUY2, usingFourCC: false, res: 160x120 - 160x120, frameIntervals: 500000-2000000
00:34:16:     use buffering: false - 0, fourCC: 'YUY2'
00:34:16:     audio device: Disable,
00:34:16:     audio device id Disabled,
00:34:16:     audio time offset 0,
00:34:16:
00:34:16: Using directshow input
00:34:16: Using Window Capture
00:34:16: Using graphics capture
Warning -- DShowPlugin: control->Run failed, result = 8007001F
00:34:17: Scene buffering time set to 400
00:34:17: ------------------------------------------
00:34:17: Video Encoding: x264
00:34:17:     fps: 30
00:34:17:     width: 1064, height: 600
00:34:17:     preset: veryfast
00:34:17:     profile: main
00:34:17:     keyint: 60
00:34:17:     CBR: yes
00:34:17:     CFR: yes
00:34:17:     max bitrate: 800
00:34:17:     buffer size: 800
00:34:20: ------------------------------------------
00:34:20:     device: Full HD 1080p Web Camera,
00:34:20:     device id \\?\usb#vid_2084&pid_0805&mi_00#6&18e5bba7&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
00:34:20:     chosen type: YUY2, usingFourCC: false, res: 160x120 - 160x120, frameIntervals: 500000-2000000
00:34:20:     use buffering: false - 0, fourCC: 'YUY2'
00:34:20:     audio device: Disable,
00:34:20:     audio device id Disabled,
00:34:20:     audio time offset 0,
00:34:20:
00:34:21: Using directshow input
00:34:23: Total frames encoded: 163, total frames duplicated: 36 (22.09%)
00:34:23: Total frames rendered: 144, number of late frames: 2 (1.39%) (it's okay for some frames to be late)
00:34:23:
00:34:23: Profiler time results:
00:34:23:
00:34:23: ==============================================================
00:34:23: video thread frame - [100%] [avg time: 9.833 ms] [children: 4.57%] [unaccounted: 95.4%]
00:34:23: | scene->Preprocess - [1.96%] [avg time: 0.193 ms]
00:34:23: | GPU download and conversion - [2.6%] [avg time: 0.256 ms] [children: 2.17%] [unaccounted: 0.437%]
00:34:23: | | flush - [2.04%] [avg time: 0.201 ms]
00:34:23: | | CopyResource - [0.0814%] [avg time: 0.008 ms]
00:34:23: | | conversion to 4:2:0 - [0.0407%] [avg time: 0.004 ms]
00:34:23: Convert444Thread - [100%] [avg time: 0.73 ms] [children: 98.6%] [unaccounted: 1.37%]
00:34:23: | Convert444toNV12 - [98.6%] [avg time: 0.72 ms]
00:34:23: encoder thread frame - [100%] [avg time: 1.49 ms] [children: 0.268%] [unaccounted: 99.7%]
00:34:23: | sending stuff out - [0.268%] [avg time: 0.004 ms]
00:34:23:
00:34:23:
00:34:23: Profiler CPU results:
00:34:23:
00:34:23: video thread frame - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
00:34:23: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
00:34:23: | GPU download and conversion - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
00:34:23: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
00:34:23: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
00:34:23: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
00:34:23: Convert444Thread - [cpu time: avg 0.726 ms, total 93.75 ms] [avg calls per frame: 1]
00:34:23: | Convert444toNV12 - [cpu time: avg 0.726 ms, total 93.75 ms] [avg calls per frame: 1]
00:34:23: encoder thread frame - [cpu time: avg 1.342 ms, total 218.75 ms] [avg calls per frame: 1]
00:34:23: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
00:34:23:
00:34:23: =====Stream End: 2015-10-17, 00:34:23=================================================
Last Game Capture Log:
2015-10-14, 06:43:29: we're booting up:
06:43:29: CaptureThread: attached to process HeroesOfTheStorm_x64.exe
06:43:29: D3D9 Present
06:43:29: DXGI Present
06:43:29: GL Present
06:43:29: DirectDraw capture: Windows 8 not supported yet
06:43:29: (half life scientist) everything..  seems to be in order
06:43:29: D3D9EndScene called
06:43:29: D3DPRESENT_PARAMETERS {
06:43:29:     BackBufferWidth: 1600
06:43:29:     BackBufferHeight: 900
06:43:29:     BackBufferFormat: D3DFMT_X8R8G8B8
06:43:29:     BackBufferCount: 1
06:43:29:     MultiSampleType: D3DMULTISAMPLE_NONE
06:43:29:     MultiSampleQuality: 0
06:43:29:     SwapEffect: D3DSWAPEFFECT_DISCARD
06:43:29:     hDeviceWindow: 1706652
06:43:29:     Windowed: false
06:43:29:     EnableAutoDepthStencil: false
06:43:29:     AutoDepthStencilFormat: D3DFMT_UNKNOWN
06:43:29:     Flags: None
06:43:29:     FullScreen_RefreshRateInHz: 60
06:43:29:     PresentationInterval: 2147483648
06:43:29: };
06:43:29: successfully set up d3d9 hooks
06:43:29: D3D9SwapPresent called
06:43:29: DoD3D9GPUHook: success
06:43:29: D3DSURFACE_DESC {
06:43:29:     Format: D3DFMT_X8R8G8B8
06:43:29:     Type: D3DRTYPE_SURFACE
06:43:29:     Usage: D3DUSAGE_RENDERTARGET
06:43:29:     Pool: D3DPOOL_DEFAULT
06:43:29:     Width: 1600
06:43:29:     Height: 900
06:43:29: };
06:43:29: successfully capturing d3d9 frames via GPU
06:44:20: D3D9Reset called
06:44:20: ---------------------- Cleared D3D9 Capture ----------------------
06:44:20: successfully set up d3d9 hooks
06:44:21: D3D9EndScene called
06:44:21: D3D9SwapPresent called
06:44:21: DoD3D9GPUHook: success
06:44:21: D3DSURFACE_DESC {
06:44:21:     Format: D3DFMT_X8R8G8B8
06:44:21:     Type: D3DRTYPE_SURFACE
06:44:21:     Usage: D3DUSAGE_RENDERTARGET
06:44:21:     Pool: D3DPOOL_DEFAULT
06:44:21:     MultiSampleType: D3DMULTISAMPLE_NONE
06:44:21:     MultiSampleQuality: 0
06:44:21:     Width: 1600
06:44:21:     Height: 900
06:44:21: };
06:44:21: successfully capturing d3d9 frames via GPU
06:44:22: DirectDraw capture: Windows 8 not supported yet
It's my HD webcam that's giving the issue, when I toggle it off, then back on,. the red goes away but the webcam only turns on (the light showing it's on anyway) for a split second then turns off with no capture showing in OBS.
selonianth
Device: Full HD 1080p Web Camera
  Pin: Capture
    category: PIN_CATEGORY_CAPTURE
    00.) major type: MEDIATYPE_Video
         sub type: MEDIASUBTYPE_YUY2
         format type: FORMAT_VideoInfo (YUY2)
    01.) major type: MEDIATYPE_Video
         format type: FORMAT_VideoInfo2
    02.) major type: MEDIATYPE_Video
         sub type: MEDIASUBTYPE_MJPG
         format type: FORMAT_VideoInfo (MJPG)
    03.) major type: MEDIATYPE_Video
  Pin: Still
    category: PIN_CATEGORY_STILL
That's the log from the pins and caps zip. If my webcam is capturing to another application it's doing so without me having it open at all, and without the light telling me it's on.
DragonMage305
Device: TOSHIBA Web Camera - HD
Pin: Capture
04.) major type: MEDIATYPE_Video
05.) major type: MEDIATYPE_Video
06.) major type: MEDIATYPE_Video
07.) major type: MEDIATYPE_Video
08.) major type: MEDIATYPE_Video
09.) major type: MEDIATYPE_Video
10.) major type: MEDIATYPE_Video
11.) major type: MEDIATYPE_Video
12.) major type: MEDIATYPE_Video
13.) major type: MEDIATYPE_Video
14.) major type: MEDIATYPE_Video
15.) major type: MEDIATYPE_Video
16.) major type: MEDIATYPE_Video
17.) major type: MEDIATYPE_Video
18.) major type: MEDIATYPE_Video
19.) major type: MEDIATYPE_Video
20.) major type: MEDIATYPE_Video
21.) major type: MEDIATYPE_Video
22.) major type: MEDIATYPE_Video
23.) major type: MEDIATYPE_Video
24.) major type: MEDIATYPE_Video
25.) major type: MEDIATYPE_Video
26.) major type: MEDIATYPE_Video
27.) major type: MEDIATYPE_Video
28.) major type: MEDIATYPE_Video
29.) major type: MEDIATYPE_Video
30.) major type: MEDIATYPE_Video
31.) major type: MEDIATYPE_Video
32.) major type: MEDIATYPE_Video
33.) major type: MEDIATYPE_Video
34.) major type: MEDIATYPE_Video
35.) major type: MEDIATYPE_Video
Pin: Still
I was just streaming fine the other day. Now it's constantly in the red. Super odd.
Jutah
Hi, i have same problem with red screen on my capture device, I don't know exact brand (if it exist at all) and model of device but found it here: http://aliexpress.com/item/Multiple-Component-Splitter-Box-Compatible-with-Xbox-360-Wii-PS3-PS2-PSP-2000-3000-series-VD001/758680212.html
In device manager it calls himself as USB 28285 Device and USB 2825X Device with device ID
USB\VID_EB1A&PID_8285&REV_0100&MI_01
and
Here is log
Device: WDM 2828x Capture
Pin: Запись
Pin: VBI
category: PIN_CATEGORY_VBI
00.) major type: {F72A76E1-EB0A-11D0-AC-E4-00-00-C0-CC-16-BA}
sub type: {CA20D9A0-3E3E-11D1-9B-F9-00-C0-4F-BB-DE-BF}
format type: {F72A76E0-EB0A-11D0-AC-E4-00-00-C0-CC-16-BA}
01.) major type: {F72A76E1-EB0A-11D0-AC-E4-00-00-C0-CC-16-BA}
If i remember correctly it worked in OBS in the august or september when i recieved device.
Sapiens
@Jutah If it doesn't have DirectShow drivers it isn't going to work. If you don't even know what the device is or who manufactures it, finding those drivers (or determining if they even exist) is going to be pretty difficult if not impossible.
Steven Willett
Hey,
So all was working fine until 48 hours ago, I plugged an older Logitech webcam in and now my newer webcam is not recognised by OBS, I just get the red screen, been trying to figure it out but no matter what I do, still red screen, I have had no luck, here is the info I have collected:
  • OS = Windows 10
  • Webcam = Logitech B910 HD
  • OBS = V0.657b
  • Tried re-installing OBS
  • DirectShow Pin List & Caps = (Log Below)
  • Issue = Red Screen
  • Webcam Drivers = Attempted the following:
    • Un-installing & Re-installing
    • Removing Device completely
    • Updating Drivers
    • Installed Logitech Software for managing drivers
    • Removal of all drivers directly so webcam should resort to UVC drivers for windows 10 but no luck
  • Tried every variation of setting adjustment & Webcam device setting adjustment to try to get working
  • Works fine in the Windows 10 camera app but if I try to use in a window scene its just black?
I have managed (2 days ago) to stream with this webcam in OBS, however as soon as i plugged an older 2nd webcam into my PC (Logitech as well) the newer webcam only shows in OBS as a red screen.
I have taken the steps to ensure (to the best of my understanding) remove all the webcams and their respective drivers from my machine but feel I may be missing something?
I removed all files shown in each devices driver window to ensure all related items where removed in case of any conflict (Old v New)
Any pointers appreciated.
Steven Willett
Direct Show Pin List and Caps
Device: Logitech B910 HD Webcam
Pin: Capture
sub type: MEDIASUBTYPE_RGB24
format type: FORMAT_VideoInfo (00000000)
36.) major type: MEDIATYPE_Video
37.) major type: MEDIATYPE_Video
38.) major type: MEDIATYPE_Video
39.) major type: MEDIATYPE_Video
40.) major type: MEDIATYPE_Video
41.) major type: MEDIATYPE_Video
42.) major type: MEDIATYPE_Video
43.) major type: MEDIATYPE_Video
44.) major type: MEDIATYPE_Video
45.) major type: MEDIATYPE_Video
46.) major type: MEDIATYPE_Video
47.) major type: MEDIATYPE_Video
48.) major type: MEDIATYPE_Video
49.) major type: MEDIATYPE_Video
Steven Willett
50.) major type: MEDIATYPE_Video
51.) major type: MEDIATYPE_Video
52.) major type: MEDIATYPE_Video
53.) major type: MEDIATYPE_Video
54.) major type: MEDIATYPE_Video
55.) major type: MEDIATYPE_Video
56.) major type: MEDIATYPE_Video
sub type: MEDIASUBTYPE_I420
format type: FORMAT_VideoInfo (I420)
57.) major type: MEDIATYPE_Video
58.) major type: MEDIATYPE_Video
59.) major type: MEDIATYPE_Video
60.) major type: MEDIATYPE_Video
61.) major type: MEDIATYPE_Video
62.) major type: MEDIATYPE_Video
63.) major type: MEDIATYPE_Video
64.) major type: MEDIATYPE_Video
65.) major type: MEDIATYPE_Video
66.) major type: MEDIATYPE_Video
67.) major type: MEDIATYPE_Video
68.) major type: MEDIATYPE_Video
69.) major type: MEDIATYPE_Video
70.) major type: MEDIATYPE_Video
71.) major type: MEDIATYPE_Video
72.) major type: MEDIATYPE_Video
73.) major type: MEDIATYPE_Video
74.) major type: MEDIATYPE_Video
75.) major type: MEDIATYPE_Video
76.) major type: MEDIATYPE_Video
77.) major type: MEDIATYPE_Video
78.) major type: MEDIATYPE_Video
79.) major type: MEDIATYPE_Video
80.) major type: MEDIATYPE_Video
81.) major type: MEDIATYPE_Video
82.) major type: MEDIATYPE_Video
83.) major type: MEDIATYPE_Video
Pin: Still
Steven Willett
Device: AVerMedia HD Capture C985 Bus 5
Pin: Virtual Video Out
category: {494B594A-026C-48A3-9A-8A-EC-C3-5C-FE-33-20}
00.) major type: MEDIATYPE_Stream
sub type: {C5C928BE-6F6D-42B6-B6-E0-43-B5-62-D9-73-C1}
format type: FORMAT_None
Pin: Capture
sub type: {32315659-F072-40CA-82-9D-47-D5-D2-83-54-22}
format type: FORMAT_VideoInfo (YV12)
sub type: MEDIASUBTYPE_YV12
Pin: VBI
Pin: PCM Out
00.) major type: MEDIATYPE_Audio
sub type: MEDIASUBTYPE_PCM
format type: FORMAT_WaveFormatEx
01.) major type: MEDIATYPE_Audio
02.) major type: MEDIATYPE_Audio
Sorry for many posts - Forum complained about the Pin List & Caps being to long.
Mike Prendergast
Jim - having issues with an analog ntsc video (elgato video capture). OBS recognizes the card but does not pick up the video and I get the red screen. However I can make it work in Google Hangouts. Below is the code I got from running the requested app:
Device: HD WebCam
Pin: Capture
Device: Elgato Video Capture
Pin: Capture
sub type: MEDIASUBTYPE_UYVY
format type: FORMAT_VideoInfo (UYVY)
sub type: {20203859-0000-0010-80-00-00-AA-00-38-9B-71}
format type: FORMAT_VideoInfo (Y8 )
Pin: Audio Out
Pin: VBI
The LuKaS
I want to stream with webcam and it turns into red
Device: USB2.0 PC Camera (SN9C201)
Pin: Capture
Pin: Still
Device: ManyCam Virtual Webcam
Pin: Capture
David Martinez
Device: AVerMedia GC550 Video Capture
Pin: Capture
Pin: Audio Out
Pin: VBI
Device: Lenovo EasyCamera
Pin: Capture
havoc
hello I am new here if anyone would like to help mw that would be awesome I have ben trying to link my avermedia C875 and ever time all I do all I get is a red screen can someone help me to I have no clue what I am doing please and thank u
Thomas Toft
Device: AXIS V5915
Pin: Video
The problem only exists in OBS 64 bit. If I create a profile in OBS 32 and open that profile in 64 bit I get the camera name etc., but if I make the profile in 64 bit version it doesn't recognize it.
Aly199
from https://obsproject.com/forum/threads/webcam-showing-up-as-red-box.48306/
Direct show pins and caps
Device: Logitech HD Webcam C615
Pin: Capture
Pin: Still
  • 2016-05-20-0607-43.log
  • 2016-05-20-0609-05.log
  • 2016-05-20-0609-29.log
  • 2016-05-20-0610-18.log
  • 2016-05-20-0612-09.log
  • 2016-05-20-0613-11.log
  • 2016-05-20-0618-53.log
  • 2016-05-20-0625-41.log
  • 2016-05-20-0626-31.log
  • 2016-05-20-0657-37.log
PikaPikaChu
I'm attempting to record using a Wirecast Virtual Camera as a webcam, and it shows up as red. Here's the log file
11:24:56: CLR host plugin strings not found, dynamically loading 4 strings
11:24:56: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
11:24:56: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
11:24:56: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
11:24:56: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
11:24:56: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
11:24:58: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
11:24:59: CLRHost:: Could not find/load browser settings at location C:\Users\Lily\AppData\Roaming\OBS\pluginData\browser.json
11:24:59: CLRHost:: Exception: System.IO.FileNotFoundException: Could not find file 'C:\Users\Lily\AppData\Roaming\OBS\pluginData\browser.json'.
11:24:59: File name: 'C:\Users\Lily\AppData\Roaming\OBS\pluginData\browser.json'
11:24:59:    at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
11:24:59:    at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
11:24:59:    at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
11:24:59:    at CLRBrowserSourcePlugin.Shared.BrowserSettings.Reload()
11:25:00: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
11:38:43: Open Broadcaster Software v0.657b - 32bit (´・ω・`)
11:38:43: -------------------------------
11:38:43: CPU Name: Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz
11:38:43: CPU Speed: 1995MHz
11:38:43: Physical Memory:  4095MB Total, 968MB Free
11:38:43: stepping id: 7, model 42, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
11:38:43: monitor 1: pos={0, 0}, size={1366, 768}
11:38:43: Windows Version: 10.0 Build 10586 (revision 0)
11:38:43: Aero is Enabled
11:38:43: OBS Modules:
11:38:43: Base Address     Module
11:38:43: 00230000         OBS.exe
11:38:43: 5DAC0000         OBSApi.dll
11:38:43: 61DA0000         CLRHostPlugin.dll
11:38:43: 5DE50000         DShowPlugin.dll
11:38:43: 5D8D0000         GraphicsCapture.dll
11:38:43: 5C6C0000         NoiseGate.dll
11:38:43: 636A0000         PSVPlugin.dll
11:38:43: 61D80000         scenesw.dll
11:38:43: ------------------------------------------
11:38:43: Adapter 1
11:38:43:   Video Adapter: Intel(R) HD Graphics 3000
11:38:43:   Video Adapter Dedicated Video Memory: 33554432
11:38:43:   Video Adapter Shared System Memory: 1711276032
11:38:43:   Video Adapter Output 1: pos={0, 0}, size={1366, 768}, attached=true
11:38:43: =====Stream Start: 2016-07-04, 11:38:43===============================================
11:38:43:   Multithreaded optimizations: On
11:38:43:   Base resolution: 1366x768
11:38:43:   Output resolution: 1364x768
11:38:43: Loading up D3D10 on Intel(R) HD Graphics 3000 (Adapter 1)...
11:38:43: Audio Format: 48000 Hz
11:38:43: Audio Channels: 2 Ch
11:38:43: Playback device {0.0.0.00000000}.{ba45c905-1aee-4389-a22d-8ff5009f45e4}
11:38:43: Using desktop audio input: Speakers (Logitech USB Headset)
11:38:43: Global Audio time adjust: 0
11:38:43: Using auxilary audio input: Microphone (Logitech USB Headset)
11:38:43: Mic time offset: 0
11:38:43: Audio Encoding: AAC
11:38:43:     bitrate: 128
Warning -- DShowPlugin: Could not get device video pin
11:38:43: Using directshow input
11:38:43: Scene buffering time set to 700
11:38:43: Video Encoding: x264
11:38:43:     fps: 30
11:38:43:     width: 1364, height: 768
11:38:43:     preset: veryfast
11:38:43:     profile: high
11:38:43:     keyint: 250
11:38:43:     CBR: yes
11:38:43:     CFR: yes
11:38:43:     max bitrate: 1000
11:38:43:     buffer size: 1000
11:39:00: Total frames encoded: 462, total frames duplicated: 0 (0.00%)
11:39:00: Total frames rendered: 487, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
11:39:00:
11:39:00: Profiler time results:
11:39:00:
11:39:00: ==============================================================
11:39:00: video thread frame - [100%] [avg time: 1.926 ms] [children: 33.3%] [unaccounted: 66.7%]
11:39:00: | scene->Preprocess - [0.156%] [avg time: 0.003 ms]
11:39:00: | GPU download and conversion - [33.1%] [avg time: 0.638 ms] [children: 30.4%] [unaccounted: 2.75%]
11:39:00: | | flush - [18.1%] [avg time: 0.349 ms]
11:39:00: | | CopyResource - [11.7%] [avg time: 0.226 ms]
11:39:00: | | conversion to 4:2:0 - [0.519%] [avg time: 0.01 ms]
11:39:00: Convert444Threads - [100%] [avg time: 1.545 ms] [children: 98.7%] [unaccounted: 1.29%]
11:39:00: | Convert444toNV12 - [98.7%] [avg time: 1.525 ms]
11:39:00: encoder thread frame - [100%] [avg time: 2.766 ms] [children: 0.253%] [unaccounted: 99.7%]
11:39:00: | sending stuff out - [0.253%] [avg time: 0.007 ms]
11:39:00:
11:39:00:
11:39:00: Profiler CPU results:
11:39:00:
11:39:00: video thread frame - [cpu time: avg 1.732 ms, total 843.75 ms] [avg calls per frame: 1]
11:39:00: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
11:39:00: | GPU download and conversion - [cpu time: avg 0.77 ms, total 375 ms] [avg calls per frame: 1]
11:39:00: | | flush - [cpu time: avg 0.32 ms, total 156.25 ms] [avg calls per frame: 1]
11:39:00: | | CopyResource - [cpu time: avg 0.336 ms, total 156.25 ms] [avg calls per frame: 1]
11:39:00: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
11:39:00: Convert444Threads - [cpu time: avg 1.518 ms, total 1406.25 ms] [avg calls per frame: 2]
11:39:00: | Convert444toNV12 - [cpu time: avg 1.501 ms, total 1390.63 ms] [avg calls per frame: 2]
11:39:00: encoder thread frame - [cpu time: avg 2.637 ms, total 1218.75 ms] [avg calls per frame: 1]
11:39:00: | sending stuff out - [cpu time: avg 0.033 ms, total 15.625 ms] [avg calls per frame: 1]
11:39:00:
11:39:00: =====Stream End: 2016-07-04, 11:39:00=================================================
11:39:09: CLR host plugin instance deleted; removing dynamically loaded localization strings
Last game capture log:
2016-04-24, 11:17:25: we're booting up:
11:17:25: CaptureThread: attached to process DeSmuME_0.9.11_x86.exe
11:17:25: GL Present
11:17:25: DirectDraw Present
11:17:25: (half life scientist) everything..  seems to be in order
11:17:25: Got DirectDraw interface pointer
11:17:25: found primary surface
11:17:25: called SetupDDraw()
11:17:25: SetupDDraw: no surface descriptor found, creating a new one (not an error)
11:17:25: CopyDDrawTextureThread: waiting for copyEvents
11:17:25: SetupDDraw: found 32bit format (using plain copy)
11:17:25: SetupDDraw: primary surface width = 1366, height = 768
11:17:25: SetupDDraw successfull
RemsWorldMC
PLEASE HELP ME
AverMedia red screen
Device: Chicony USB 2.0 Camera
Pin: Capturer
Pin: Fixe
Device: AVerMedia USB HD Capture
Pin: Stream Out
sub type: {E06D8023-DB46-11CF-B4-D1-00-80-5F-6C-BB-EA}
Pin: Virtual Stream Out
Device: XSplitBroadcaster
Pin: Output
sub type: MEDIASUBTYPE_NV12
format type: FORMAT_VideoInfo (NV12)
sub type: MEDIASUBTYPE_AYUV
format type: FORMAT_VideoInfo (AYUV)
sub type: MEDIASUBTYPE_RGB32
Status
