Bug Report If you get red output from a device, read here
Status
Not open for further replies.
faasvriend
I get a red screen when recording Hauppauge HD PVR 2 Plus Gaming Edition
Device: Hauppauge Siena Video Capture
Pin: 656
category: {4EF89945-4D43-48D7-A4-42-A1-B4-E7-81-30-36}
00.) major type: MEDIATYPE_Video
sub type: {32574348-005B-4504-99-F8-90-82-6C-80-66-57}
format type: FORMAT_VideoInfo (CXF2)
Device: ASUS Virtual Camera
Pin: Capture
category: PIN_CATEGORY_CAPTURE
sub type: MEDIASUBTYPE_RGB24
format type: FORMAT_VideoInfo (00000000)
01.) major type: MEDIATYPE_Video
02.) major type: MEDIATYPE_Video
03.) major type: MEDIATYPE_Video
04.) major type: MEDIATYPE_Video
MorningBacon
Device: Microsoft LifeCam HD-3000
Pin: Capture
sub type: MEDIASUBTYPE_YUY2
format type: FORMAT_VideoInfo (YUY2)
format type: FORMAT_VideoInfo2
05.) major type: MEDIATYPE_Video
06.) major type: MEDIATYPE_Video
07.) major type: MEDIATYPE_Video
08.) major type: MEDIATYPE_Video
09.) major type: MEDIATYPE_Video
10.) major type: MEDIATYPE_Video
11.) major type: MEDIATYPE_Video
12.) major type: MEDIATYPE_Video
13.) major type: MEDIATYPE_Video
14.) major type: MEDIATYPE_Video
15.) major type: MEDIATYPE_Video
16.) major type: MEDIATYPE_Video
17.) major type: MEDIATYPE_Video
18.) major type: MEDIATYPE_Video
19.) major type: MEDIATYPE_Video
20.) major type: MEDIATYPE_Video
21.) major type: MEDIATYPE_Video
22.) major type: MEDIATYPE_Video
23.) major type: MEDIATYPE_Video
24.) major type: MEDIATYPE_Video
25.) major type: MEDIATYPE_Video
26.) major type: MEDIATYPE_Video
27.) major type: MEDIATYPE_Video
28.) major type: MEDIATYPE_Video
29.) major type: MEDIATYPE_Video
30.) major type: MEDIATYPE_Video
31.) major type: MEDIATYPE_Video
32.) major type: MEDIATYPE_Video
33.) major type: MEDIATYPE_Video
34.) major type: MEDIATYPE_Video
35.) major type: MEDIATYPE_Video
36.) major type: MEDIATYPE_Video
37.) major type: MEDIATYPE_Video
38.) major type: MEDIATYPE_Video
39.) major type: MEDIATYPE_Video
40.) major type: MEDIATYPE_Video
41.) major type: MEDIATYPE_Video
42.) major type: MEDIATYPE_Video
43.) major type: MEDIATYPE_Video
  • 2013-11-18-1929-32.log
Lain
Lain
They probably don't provide 64bit drivers in that case (though it's microsoft so usually they would)
bidmoon
Device: AVerMedia USB HD Capture
  Pin: Stream Out
    00.) major type: MEDIATYPE_Stream
         sub type: {E06D8023-DB46-11CF-B4-D1-00-80-5F-6C-BB-EA}
         format type: FORMAT_None
  Pin: Virtual Stream Out
Device: LGP Stream Engine
im getting the red screen on obs as well and i also cant click the configure button to try and set it up when i pick my device. any thoughts on that?
paibox
heros in an halfshel
The LGP Stream Engine only works in the 32-bit version of OBS, so please make sure that you are using that. Using the device directly does not work, as there is no support for encoded video output, you must use the Stream Engine.
FlyntNSteel
Device: OEM Device
Pin: Capture
Pin: AudioOut
00.) major type: MEDIATYPE_Audio
sub type: MEDIASUBTYPE_PCM
format type: FORMAT_WaveFormatEx
Pin: VBI
category: PIN_CATEGORY_VBI
00.) major type: {F72A76E1-EB0A-11D0-AC-E4-00-00-C0-CC-16-BA}
sub type: {CA20D9A0-3E3E-11D1-9B-F9-00-C0-4F-BB-DE-BF}
format type: {F72A76E0-EB0A-11D0-AC-E4-00-00-C0-CC-16-BA}
01.) major type: {F72A76E1-EB0A-11D0-AC-E4-00-00-C0-CC-16-BA}
Device: AmaRec Video Capture
Pin: AmaRec Video Capture
sub type: MEDIASUBTYPE_RGB32
brezorian
Device: Live! Cam Vista IM (VF0420)
Pin: Capture
sub type: MEDIASUBTYPE_MJPG
format type: FORMAT_VideoInfo (MJPG)
sub type: MEDIASUBTYPE_I420
format type: FORMAT_VideoInfo (I420)
I use the device named: Live! Cam Vista IM (VF0420) from creative
http://support.creative.com/Products/Pr ... IM+(VF0420)&CatName=Web+Cameras
I just get a red box in every resolution with any type of output format! Help pls, thx ;)
tronicx
Device: Hauppauge HD PVR Capture Device
Pin: Virtual Video Out
sub type: {F7AD521F-1CF5-46EF-9D-00-68-5A-D4-D6-31-84}
Pin: Virtual Audio Out
category: {9A990B97-05FB-4D92-B4-96-C6-AD-FD-2B-07-A6}
sub type: {C669BE66-8310-4A52-84-69-DE-07-39-89-3F-C0}
Poeguyz
I'm using a Dazzle DVC100 and i'm getting a red screen. i've had this problem before with my easycap but the problem is it only does this on my desktop my laptop has no problems at all. i think it might be in use by other software but i don't know by what, i have closed down skype but that didn't help. if anyone knows a way to find out what could be using it that would be great.
401k
Hello! I've been having problems with my Kinect connected to my computer. It is working through a third party program which I imagine might be the issue, but I was wondering if any help could be offered.
Just let me know if you need any more info.
Device: Kinect Camera
  Pin: Capture
19:35:09: Open Broadcaster Software v0.611b - 32bit (´・ω・`)
19:35:09: -------------------------------
19:35:09: CPU Name: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
19:35:09: CPU Speed: 3400MHz
19:35:09: Physical Memory:  4095MB Total, 4095MB Free
19:35:09: stepping id: 3, model 60, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
19:35:09: monitor 1: pos={0, 0}, size={1920, 1080}
19:35:09: Windows Version: 6.2 Build 9200
19:35:09: Aero is Enabled
19:35:09: OBS Modules:
19:35:09: Base Address     Module
19:35:09: 013E0000         OBS.exe
19:35:09: 73420000         OBSApi.dll
19:35:09: 6F050000         DShowPlugin.dll
19:35:09: 6F030000         GraphicsCapture.dll
19:35:09: 6F010000         NoiseGate.dll
19:35:09: 6EFF0000         PSVPlugin.dll
19:35:09: ------------------------------------------
19:35:09: Adapter 1
19:35:09:   Video Adapter: AMD Radeon HD 7800 Series
19:35:09:   Video Adapter Dedicated Video Memory: 2120257536
19:35:09:   Video Adapter Shared System Memory: 2174644224
19:35:09:   Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
19:35:09: =====Stream Start: 2014-02-16, 19:35:09===============================================
19:35:09:   Multithreaded optimizations: On
19:35:09:   Base resolution: 1920x1080
19:35:09:   Output resolution: 1280x720
19:35:09: Loading up D3D10 on AMD Radeon HD 7800 Series (Adapter 1)...
19:35:09: Audio Format: 44100hz
19:35:09: Playback device {0.0.0.00000000}.{13d7c447-ac94-45db-8c83-3473935076b4}
19:35:09: Using desktop audio input: Speakers (Realtek High Definition Audio)
19:35:09: Using auxilary audio input: Microphone (Realtek High Definition Audio)
19:35:10: ------------------------------------------
19:35:10: Audio Encoding: MP3
19:35:10:     bitrate: 128
19:35:10: Using text output
19:35:10: Using graphics capture
19:35:10: Scene buffering time set to 400
19:35:10: Video Encoding: x264
19:35:10:     fps: 60
19:35:10:     width: 1280, height: 720
19:35:10:     preset: faster
19:35:10:     profile: main
19:35:10:     keyint: 120
19:35:10:     CBR: yes
19:35:10:     CFR: no
19:35:10:     max bitrate: 2000
19:35:10:     buffer size: 4200
19:35:18: Total frames encoded: 497, total frames duplicated: 0 (0.00%)
19:35:18: Total frames rendered: 500, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
19:35:18:
19:35:18: Profiler time results:
19:35:18:
19:35:18: ==============================================================
19:35:18: video thread frame - [100%] [avg time: 0.534 ms] [children: 23.6%] [unaccounted: 76.4%]
19:35:18: | scene->Preprocess - [1.69%] [avg time: 0.009 ms]
19:35:18: | GPU download and conversion - [21.9%] [avg time: 0.117 ms] [children: 19.7%] [unaccounted: 2.25%]
19:35:18: | | flush - [18%] [avg time: 0.096 ms]
19:35:18: | | CopyResource - [1.31%] [avg time: 0.007 ms]
19:35:18: | | conversion to 4:2:0 - [0.375%] [avg time: 0.002 ms]
19:35:18: Convert444Threads - [100%] [avg time: 0.471 ms] [children: 99.2%] [unaccounted: 0.849%]
19:35:18: | Convert444toNV12 - [99.2%] [avg time: 0.467 ms]
19:35:18: encoder thread frame - [100%] [avg time: 0.768 ms] [children: 0.13%] [unaccounted: 99.9%]
19:35:18: | sending stuff out - [0.13%] [avg time: 0.001 ms]
19:35:18:
19:35:18:
19:35:18: Profiler CPU results:
19:35:18:
19:35:18: video thread frame - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:35:18: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:35:18: | GPU download and conversion - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:35:18: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:35:18: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:35:18: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:35:18: Convert444Threads - [cpu time: avg 0.346 ms, total 328.125 ms] [avg calls per frame: 2]
19:35:18: | Convert444toNV12 - [cpu time: avg 0.346 ms, total 328.125 ms] [avg calls per frame: 2]
19:35:18: encoder thread frame - [cpu time: avg 0.099 ms, total 46.875 ms] [avg calls per frame: 1]
19:35:18: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:35:18:
19:35:18: =====Stream End: 2014-02-16, 19:35:18=================================================
19:35:28: =====Stream Start: 2014-02-16, 19:35:28===============================================
19:35:28:   Multithreaded optimizations: On
19:35:28:   Base resolution: 1920x1080
19:35:28:   Output resolution: 1280x720
19:35:28: ------------------------------------------
19:35:28: Loading up D3D10 on AMD Radeon HD 7800 Series (Adapter 1)...
19:35:28: Audio Format: 44100hz
19:35:28: Playback device {0.0.0.00000000}.{13d7c447-ac94-45db-8c83-3473935076b4}
19:35:28: Using desktop audio input: Speakers (Realtek High Definition Audio)
19:35:28: Using auxilary audio input: Microphone (Realtek High Definition Audio)
19:35:28: Audio Encoding: MP3
19:35:28:     bitrate: 128
19:35:28: Using text output
19:35:28: Using graphics capture
19:35:28: Scene buffering time set to 400
19:35:28: Video Encoding: x264
19:35:28:     fps: 60
19:35:28:     width: 1280, height: 720
19:35:28:     preset: faster
19:35:28:     profile: main
19:35:28:     keyint: 120
19:35:28:     CBR: yes
19:35:28:     CFR: no
19:35:28:     max bitrate: 2000
19:35:28:     buffer size: 4200
19:35:40: ------------------------------------------
19:35:40:     device: (null),
19:35:40:     device id (null),
19:35:40:     chosen type: RGB24, usingFourCC: false, res: 160x120 - 1600x1200, frameIntervals: 0-640000000
19:35:40:     use buffering: false - 0, fourCC: 00000000
19:35:40:     audio device: Disable,
19:35:40:     audio device id Disabled,
19:35:40:
Warning -- DShowPlugin: Failed to connect the video device pin to the video capture pin, result = 80040217
19:35:40: Using directshow input
19:35:52: Total frames encoded: 1392, total frames duplicated: 7 (0.50%)
19:35:52: Total frames rendered: 1390, number of late frames: 2 (0.14%) (it's okay for some frames to be late)
19:35:52:
19:35:52: Profiler time results:
19:35:52:
19:35:52: ==============================================================
19:35:52: video thread frame - [100%] [avg time: 0.627 ms] [children: 18.3%] [unaccounted: 81.7%]
19:35:52: | scene->Preprocess - [0.797%] [avg time: 0.005 ms]
19:35:52: | GPU download and conversion - [17.5%] [avg time: 0.11 ms] [children: 15.8%] [unaccounted: 1.75%]
19:35:52: | | flush - [14.2%] [avg time: 0.089 ms]
19:35:52: | | CopyResource - [1.28%] [avg time: 0.008 ms]
19:35:52: | | conversion to 4:2:0 - [0.319%] [avg time: 0.002 ms]
19:35:52: Convert444Threads - [100%] [avg time: 0.461 ms] [children: 99.1%] [unaccounted: 0.868%]
19:35:52: | Convert444toNV12 - [99.1%] [avg time: 0.457 ms]
19:35:52: encoder thread frame - [100%] [avg time: 0.757 ms] [children: 0.132%] [unaccounted: 99.9%]
19:35:52: | sending stuff out - [0.132%] [avg time: 0.001 ms]
19:35:52:
19:35:52:
19:35:52: Profiler CPU results:
19:35:52:
19:35:52: video thread frame - [cpu time: avg 0.011 ms, total 15.625 ms] [avg calls per frame: 1]
19:35:52: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:35:52: | GPU download and conversion - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:35:52: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:35:52: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:35:52: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:35:52: Convert444Threads - [cpu time: avg 0.435 ms, total 1187.5 ms] [avg calls per frame: 2]
19:35:52: | Convert444toNV12 - [cpu time: avg 0.429 ms, total 1171.88 ms] [avg calls per frame: 2]
19:35:52: encoder thread frame - [cpu time: avg 0.022 ms, total 31.25 ms] [avg calls per frame: 1]
19:35:52: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:35:52:
19:35:52: =====Stream End: 2014-02-16, 19:35:52=================================================
crackerfilms
i need to know how to fix this ASAP and i am going to be doing a charity live stream for cancer research so can someone get back to me as soon as possible please
Device: USB 2861 Device
Pin: Capture
Deepan Kumar S
i recieved a red screen on using datavideo se-900 video switcher
Device: DATAVIDEO SE-800
Pin: DV Vid Out
sub type: MEDIASUBTYPE_dvsd
format type: FORMAT_VideoInfo (dvsd)
Pin: DV A/V Out
00.) major type: MEDIATYPE_Interleaved
format type: FORMAT_DvInfo
Lain
Lain
Yea, those particular types of devices are known not to work at the moment. I need to buy one to get it working.
Status
