I'm in agonizing pain bro
like what the fuck kind of settings is this, this audio looping/echo is just absolutely fucking impossible to permanently erase that shit from existence, My twitch is absolutely muted and it still didn't work, the youtube tutorials never work, please don't just see that thread and leave bro just I fucking beg you bro please just answer
11:10:55.680: Using EGL/X11
11:10:55.680: CPU Name: 12th Gen Intel(R) Core(TM) i5-12400F
11:10:55.680: CPU Speed: 4000.000MHz
11:10:55.680: Physical Cores: 6, Logical Cores: 12
11:10:55.680: Physical Memory: 15828MB Total, 2455MB Free
11:10:55.680: Kernel Version: Linux 7.0.0-28-generic
11:10:55.680: Distribution: "Linux Mint" "22.3"
11:10:55.680: Desktop Environment: X-Cinnamon (cinnamon)
11:10:55.680: Session Type: x11
11:10:55.680: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.21.1
11:10:55.681: Qt Version: 6.4.2 (runtime), 6.4.2 (compiled)
11:10:55.681: Portable mode: false
11:10:55.702: OBS 30.0.2.1-3build1 (linux)
11:10:55.702: ---------------------------------
11:10:55.702: audio settings reset:
11:10:55.702: samples per sec: 48000
11:10:55.702: speakers: 2
11:10:55.702: max buffering: 960 milliseconds
11:10:55.702: buffering type: dynamically increasing
11:10:55.703: ---------------------------------
11:10:55.703: Initializing OpenGL...
11:10:55.866: Loading up OpenGL on adapter NVIDIA Corporation NVIDIA GeForce GTX 1650/PCIe/SSE2
11:10:55.866: OpenGL loaded successfully, version 3.3.0 NVIDIA 610.43.02, shading language 3.30 NVIDIA via Cg compiler
11:10:55.885: ---------------------------------
11:10:55.885: video settings reset:
11:10:55.885: base resolution: 1920x1080
11:10:55.885: output resolution: 1280x720
11:10:55.885: downscale filter: Bicubic
11:10:55.885: fps: 30/1
11:10:55.885: format: NV12
11:10:55.885: YUV mode: Rec. 709/Partial
11:10:55.885: NV12 texture support not available
11:10:55.885: P010 texture support not available
11:10:55.885: Audio monitoring device:
11:10:55.885: name: Default
11:10:55.885: id: default
11:10:55.891: Failed to load 'en-US' text for module: 'decklink-captions.so'
11:10:55.895: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
11:10:55.899: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
11:10:55.899: Failed to initialize module 'decklink.so'
11:10:55.964: [pipewire] No captures available
11:10:56.020: NVENC supported
11:10:56.020: VAAPI: Failed to initialize display in vaapi_device_h264_supported
11:10:56.020: FFmpeg VAAPI H264 encoding not supported
11:10:56.020: VAAPI: Failed to initialize display in vaapi_device_hevc_supported
11:10:56.020: FFmpeg VAAPI HEVC encoding not supported
11:10:56.045: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.3.4 | RPC Version: 1)
11:10:56.045: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.4.2 | Qt version (run-time): 6.4.2
11:10:56.045: [obs-websocket] [obs_module_load] Linked ASIO Version: 102801
11:10:56.060: [obs-websocket] [obs_module_load] Module loaded.
11:10:56.084: [vlc-video]: VLC 3.0.20 Vetinari found, VLC video source enabled
11:10:56.084: ---------------------------------
11:10:56.084: Loaded Modules:
11:10:56.084: vlc-video.so
11:10:56.084: text-freetype2.so
11:10:56.084: rtmp-services.so
11:10:56.084: obs-x264.so
11:10:56.084: obs-websocket.so
11:10:56.084: obs-transitions.so
11:10:56.084: obs-outputs.so
11:10:56.084: obs-filters.so
11:10:56.084: obs-ffmpeg.so
11:10:56.084: linux-v4l2.so
11:10:56.084: linux-pulseaudio.so
11:10:56.084: linux-pipewire.so
11:10:56.084: linux-jack.so
11:10:56.084: linux-capture.so
11:10:56.084: linux-alsa.so
11:10:56.084: image-source.so
11:10:56.084: frontend-tools.so
11:10:56.084: decklink-output-ui.so
11:10:56.084: decklink-captions.so
11:10:56.085: QWidget::setTabOrder: 'first' and 'second' must be in the same window
11:10:56.085: ==== Startup complete ===============================================
11:10:56.129: All scene data cleared
11:10:56.129: ------------------------------------------------
11:10:56.136: pulse-input: Server name: 'PulseAudio (on PipeWire 1.0.5) 15.0.0'
11:10:56.136: pulse-input: Audio format: s32le, 48000 Hz, 2 channels
11:10:56.137: pulse-input: Started recording from 'alsa_output.pci-0000_00_1f.3.analog-stereo.monitor' (default)
11:10:56.137: [Loaded global audio device]: 'Desktop Audio'
11:10:56.137: pulse-input: Server name: 'PulseAudio (on PipeWire 1.0.5) 15.0.0'
11:10:56.138: pulse-input: Audio format: s32le, 48000 Hz, 2 channels
11:10:56.138: pulse-input: Started recording from 'alsa_input.pci-0000_00_1f.3.analog-stereo'
11:10:56.139: [Loaded global audio device]: 'Mic/Aux'
11:10:56.139: - filter: 'Noise Suppression' (noise_suppress_filter_v2)
11:10:56.140: xshm-input: Geometry 1920x1080 @ 0,0
11:10:56.141: v4l2-input: Start capture from
11:10:56.141: v4l2-input: Unable to open device
11:10:56.141: v4l2-input: Initialization failed, errno: No such file or directory
11:10:56.144: Switched to scene 'Scene'
11:10:56.144: ------------------------------------------------
11:10:56.144: Loaded scenes:
11:10:56.144: - scene 'Scene':
11:10:56.144: - source: 'Screen Capture (XSHM)' (xshm_input)
11:10:56.144: - source: 'Video Capture Device (V4L2)' (v4l2_input)
11:10:56.726: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds (source: Desktop Audio)
11:10:56.726:
11:10:56.748: adding 42 milliseconds of audio buffering, total audio buffering is now 64 milliseconds (source: Mic/Aux)
11:10:56.748:
11:11:08.343: User Removed source 'Video Capture Device (V4L2)' (v4l2_input) from scene 'Scene'
11:11:18.726: [window-capture: 'Window Capture (Xcomposite)'] update settings:
11:11:18.726: title: Desktop
11:11:18.726: class: nemo-desktop
11:11:18.726:
11:11:18.748: User added source 'Window Capture (Xcomposite)' (xcomposite_input) to scene 'Scene'
11:11:18.791: [window-capture: 'Window Capture (Xcomposite)'] update settings:
11:11:18.791: title: #lobby-global | AirMech - Discord
11:11:18.791: class: discord
11:11:18.791:
11:11:26.390: [window-capture: 'Window Capture (Xcomposite)'] update settings:
11:11:26.390: title: OBS 30.0.2.1-3build1 - Profile: Untitled - Scenes: Untitled
11:11:26.390: class: obs
11:11:26.390:
11:11:30.823: [window-capture: 'Window Capture (Xcomposite)'] update settings:
11:11:30.823: title: Terraria.v1.4.5.6.ZeiGames.com
11:11:30.823: class: nemo
11:11:30.823:
11:12:56.077: User Removed source 'Window Capture (Xcomposite)' (xcomposite_input) from scene 'Scene'
11:13:13.003: [window-capture: 'Window Capture (Xcomposite)'] update settings:
11:13:13.003: title: Desktop
11:13:13.003: class: nemo-desktop
11:13:13.003:
11:13:13.015: User added source 'Window Capture (Xcomposite)' (xcomposite_input) to scene 'Scene'
11:13:13.053: [window-capture: 'Window Capture (Xcomposite)'] update settings:
11:13:13.053: title: #lobby-global | AirMech - Discord
11:13:13.053: class: discord
11:13:13.053:
11:13:15.785: [window-capture: 'Window Capture (Xcomposite)'] update settings:
11:13:15.785: title: Desktop
11:13:15.785: class: nemo-desktop
11:13:15.785:
11:13:22.785: [window-capture: 'Window Capture (Xcomposite)'] update settings:
11:13:22.785: title: Terraria.v1.4.5.6.ZeiGames.com
11:13:22.785: class: nemo
11:13:22.785:
11:13:26.985: [window-capture: 'Window Capture (Xcomposite)'] update settings:
11:13:26.985: title: Terraria.v1.4.5.6.ZeiGames.com
11:13:26.985: class: nemo
11:13:26.985:
11:13:27.852: [window-capture: 'Window Capture (Xcomposite)'] update settings:
11:13:27.852: title: Terraria.v1.4.5.6.ZeiGames.com
11:13:27.852: class: nemo
11:13:27.852:
11:13:51.952: [window-capture: 'Window Capture (Xcomposite)'] update settings:
11:13:51.952: title: Terraria.v1.4.5.6.ZeiGames.com
11:13:51.952: class: nemo
11:13:51.952:
11:13:53.085: [window-capture: 'Window Capture (Xcomposite)'] update settings:
11:13:53.085: title: Terraria.v1.4.5.6.ZeiGames.com
11:13:53.085: class: nemo
11:13:53.085:
11:13:53.285: [window-capture: 'Window Capture (Xcomposite)'] update settings:
11:13:53.285: title: Terraria.v1.4.5.6.ZeiGames.com
11:13:53.285: class: nemo
11:13:53.285:
11:14:04.352: [window-capture: 'Window Capture (Xcomposite)'] update settings:
11:14:04.352: title: Terraria.v1.4.5.6.ZeiGames.com
11:14:04.352: class: nemo
11:14:04.352:
11:14:04.519: [window-capture: 'Window Capture (Xcomposite)'] update settings:
11:14:04.519: title: Terraria.v1.4.5.6.ZeiGames.com
11:14:04.519: class: nemo
11:14:04.519:
11:15:56.307: alsa-input: PCM 'default' rate set to 44100
11:15:56.307: alsa-input: PCM 'default' channels set to 2
11:15:56.333: User added source 'Audio Capture Device (ALSA)' (alsa_input_capture) to scene 'Scene'
11:16:04.685: alsa-input: Failed to open 'front:CARD=PCH,DEV=0': Device or resource busy
11:16:05.686: alsa-input: Failed to open 'front:CARD=PCH,DEV=0': Device or resource busy
11:16:07.687: alsa-input: Failed to open 'front:CARD=PCH,DEV=0': Device or resource busy
11:16:10.688: alsa-input: Failed to open 'front:CARD=PCH,DEV=0': Device or resource busy
11:16:11.994: User Removed source 'Audio Capture Device (ALSA)' (alsa_input_capture) from scene 'Scene'
11:16:14.688: alsa-input: Failed to open 'front:CARD=PCH,D`': Device or resource busy
11:16:18.111: User Removed source 'Screen Capture (XSHM)' (xshm_input) from scene 'Scene'
11:16:19.688: alsa-input: Failed to open '': No such file or directory
11:16:24.689: alsa-input: Failed to open '': No such file or directory
11:16:29.689: alsa-input: Failed to open '': No such file or directory
11:16:34.689: alsa-input: Failed to open '': No such file or directory
11:16:39.689: alsa-input: Failed to open '': No such file or directory
11:16:44.690: alsa-input: Failed to open '': No such file or directory
11:16:46.987: ---------------------------------
11:16:46.987: [FFmpeg NVENC encoder: 'simple_video_stream'] settings:
11:16:46.987: encoder: NVIDIA NVENC H.264 (FFmpeg)
11:16:46.987: rate_control: CBR
11:16:46.987: bitrate: 2500
11:16:46.987: cqp: 0
11:16:46.987: keyint: 60
11:16:46.987: preset: p5
11:16:46.987: tuning: hq
11:16:46.987: multipass: qres
11:16:46.987: profile: high
Probably the OP is monitoring the audio but is using the same audio output for monitoring and for desktop.
Needs to change to something else the monitoring audio or not monitor at all.
