Input Overlay
Input Overlay v5.0.5
DanRockstreet
Hi all,
thanks for this nice program! I have a feature request. :-)
I was thinking of creating some spoken tutorials with OBS studio together with "Input history" for my favorite Software Blender, currently in a beta version 2.8.
Blender offers until version 2.79 a "screencast mode" for users be able to follow tutorials.
In version 2.8, they have not implemented Screencast keys - additionally, the problem Blender has is that sometimes keys are not displayed in certain modes. Therefore, OBS studio and the Input Overlay make sense as I have tested this now.
There are some features from Blender Screencast function that I think might be a good feature for the OBS Input Overlay:
This might even make sense for tutorial videos for other software as well.
  • Fade-out for the auto clear (nice to have), the disappearing is very harsh
  • The enable of repeated keys could be shown as a multiplication factor. If I press B five times in Blender and screencast mode, then I will see, B, then Bx2, Bx3, etc.. As soon as the auto clear has removed the last view of a depressed key, then it starts to count from 1 again
  • Enable the possibility of ignoring Left and Right key infos for SHIFT and CTRL, i.e. only show SHIFT or CTRL, regardless if L-SHIFT or R-SHIFT
  • Enable the possibility of not showing if only SHIFT, CTRL or ALT have been pressed, since they have no function for themselves in many programs.
  • Enable the six keys above the four arrow keys (Delete, Home, End, Page Up/Down, etc..)
Have a good evening!
Dan
P.S.: this is how it looks like in Blender 2.79
  • Start/Stop Display is used for the Screencast key display
  • Size of text and mouse icon is self-explanatory
  • Position of the display are is also self-explanatory
  • Text/Icon color is also clear
  • Fade Out Time is what I explained above
  • Mouse can be shown as text, icon or not at all
    or
  • Display: Box is basically a background box with color and alpha
univrsal
Hi all,
Dan
    View attachment 41432 or View attachment 41433
Well here's the current plan for input-history:
  • Repeat keys are already planned
  • Keys can be renamed using a config file, which determines what keys should have what name (renaming L-Ctrl to Ctrl)
  • All keys are supported by the plugin, some just don't have a name and therefore won't show up, I'll try to add these names in the next release
  • Disabling individual keys isn't possible, but I might change how Ctrl, Shift etc. are handled (So they'll be shown if they're used in a key combination)
  • Fading out isn't all that easy so I can't promise anything
PseudoDoctor
A: Nifty plugin, Got a pretty keyboard input to look like gamepad.
https://www.twitch.tv/videos/350992967 before fidling
https://www.twitch.tv/videos/351186404 after fidling
P.S. Shantae is harder than it looks.
2: Is there an example config file for input history? Every preset from 4.7.4b I throw in crashes OBS.
P.P.S. here's a horrible spreadsheet to help position keys.
https://docs.google.com/spreadsheets/d/1spEN6ciViJQLxGhCkwxMwu7E58dSsM2zswQHeoH4jeQ/edit?usp=sharing
PseudoDoctor
Input history doesn't use any presets, except for key-renaming or replacing keys with icons. What are you trying to do?
Any of that. Rename "I" to "aye" or Unicode Character “” (U+1F441) or a picture of an obelisk.
I'll create an example config to start from shortly, i.e. WASD and IJKL renamed to UpLeftDownRight
univrsal
1_key_count=4
2_key_order=0x0017,0x0024,0x0025,0x0026
#keyalias=Aye,Jay,Kay,Elle
I don't know if unicode characters are loaded correctly, you'll have to try that yourself, but if you only want to rename keys then the config file should look like this:
# format: 2_KEYCODE=KEYNAME
2_0x0034=.
2_0x0033=,
2_0x001B=]
2_0x001A=[
The syntax you used is for replacing keys with icons, which might be a better approach, if you want to display icons.
By the way, you can edit posts, so you don't have to post twice :P
PseudoDoctor
Nifty!
Would this be valid so that a plaintext history would show UP instead of I and DOWN instead of K?
INI:
#define VC_I 0x0017
#define VC_J 0x0024
#define VC_K 0x0025
#define VC_L 0x0026
2_0x0017=UP
2_0x0024=LEFT
2_0x0025=DOWN
2_0x0026=RIGHT
#define VC_COMMA 0x0033 // ','
#define VC_PERIOD 0x0034 // '.'
2_0x0033=BACK
2_0x0034=FORWARD
And is there a way to only display history of a subset of characters? Like having three histories, one for UP/DOWN, one for LEFT/RIGHT, and one for FORWARD/BACK?
EDIT:
Yes indeed there is, even alternate names.
Next I'll dink around with images.
INI:
2_0x0017=UP
2_0x0024=LEFT
INI:
2_0x0024=LEFT2
2_0x0025=DOWN
univrsal
Nifty!
INI:
#define VC_I 0x0017
#define VC_J 0x0024
#define VC_K 0x0025
#define VC_L 0x0026
2_0x0017=UP
2_0x0024=LEFT
2_0x0025=DOWN
2_0x0026=RIGHT
2_0x0033=BACK
2_0x0034=FORWARD
EDIT:
INI:
2_0x0017=UP
2_0x0024=LEFT
INI:
2_0x0024=LEFT2
2_0x0025=DOWN
So I assume things are working the way you wanted?
callimero
Hi!
I am also using it for Blender. Great work!
I often have the problem that L-Shift is shown repeatedly when holding it and moving the Mouse (which panns the view).
For the fading: Maybe push the entries down the history every x seconds?
BTW: I have some problems showing icons instead of Plain Text for the input History. I tried with some of the provided maps (tho only the qwuerty ones) and gave texture and *.ini files. It hust renders nothing then?
Best,
Carsten
univrsal
Hi!
Best,
Carsten
input-history doesn't take the same presets as input-overlay, I should've made that clear somewhere. The only preset that is made for input-history is called "arrow key icons", which does exactly what it sounds like: it displays actual arrows instead of "UP", "DOWN" etc.
As for the repeating of L-Shift, do you have "include mouse" enabled? I haven't taken a look at input-history in a while so it's definitely possible that there's some issues with it.
Also the fading is more complicated than it might seem. input-history uses the integrated text-source and puts all into one line of text with new-line separators. If I wanted to implement fading I'd have to either use multiple different text sources or somehow reuse the same one for each line. On top of that I haven't looked into how alpha works inside the source.
machs_einfach
Hi all,
Dan
Hi DanRockstreet and all the others.
I had the same problem, so i decided to make an own Preset to solve the problem.
The preset has the following layout.
If you like it and speak german, it would be great, if you give me an thumb up on youtube for my work.
www.youtube.com/machs_einfach
Today at 6PM is a german video online, which explains how i customized this.
OBS Input Overlay Preset selber erstellen
Greetings
Machs Einfach
  • qwerty-arrows-home.zip
  • qwerty-arrows-home-transparent.zip
adel108
Can you try opening "demo_hook.exe" in the util folder, that was inside the release archive, and see if there's any output when you press 'q'?
idk, my q work when i install first time plugin, maybe a week, and my q stop work w/o reason, my obs dont have key bind and discord, google chrome i think too
