Input Overlay
Input Overlay v5.0.5
septemberlemon
can someone share some files for showing all letter keys and [tab, caps,left shift,left ctrl,left win,left alt,space,right shift,right ctrl,right win,right alt] and all the number keys and so on,well I mean all main area keys,emmm,I mean the left-down area keys
apexden
Here you go, though changing the color with this one is about as easy as doing it with the finished texture
Hi, I need the keyboard layout psd file as well... the one for the submitted preset named wasd-extended-numeric
Zayanaut
Has anyone got this working for StreamElements OBS? I'm assuming if it doesn't work for streamlabs, if won't for Elements?
I've got it saying InputOverlays under tools but not showing as a source option
AstroTime8660
So I play FH4, and I use the WASD overlay on OBS.
But I'm playing on a Belgian AZERTY keyboard, so I searched for an azerty config file, and I found one somewhere (I think it was on discord).
Anyway, I've since learned to drive manual in-game and I use the "ù" & "=" keys to shift gears, as well as the "shift" key on the right side of the keyboard as the clutch.
I tried remapping the azerty .json with the io-cct tool so that "left-shift" -> "right-shift", "E" -> "ù", and "Q" -> "=". But it didn't work, when I changed the properties of the overlay in OBS to the new .json file, nothing happened on the overlay when I shifted gears.
I was wondering if anyone could help me.
Thanks in advance!
this is how the overlay looks, image wise I still kept the WASD keys, but config wise it's mapped onto an AZERTY kb.
and this is my keyboard, I wrote in red what I want each of the keys to be mapped onto in the image.
and here's the azerty .json I got from discord if it can help in any way
JSON:
    "default_width": 0,
    "default_height": 0,
    "space_h": 0,
    "space_v": 0,
    "flags": 0,
    "overlay_width": 572,
    "overlay_height": 403,
    "elements": [
            "type": 1,
            "pos": [
                0,
                137
            "id": "keyboard button1",
            "z_level": 0,
            "mapping": [
                481,
                1,
                157,
                128
            "code": 42
            "type": 1,
            "pos": [
                0,
                275
            "id": "keyboard button2",
            "z_level": 0,
            "mapping": [
                1121,
                1,
                158,
                128
            "code": 29
            "type": 1,
            "pos": [
                131,
                0
            "id": "keyboard button3",
            "z_level": 0,
            "mapping": [
                1,
                1,
                157,
                128
            "code": 30
            "type": 1,
            "pos": [
                269,
                0
            "id": "keyboard button4",
            "z_level": "0",
            "mapping": [
                161,
                1,
                157,
                128
            "code": 44
            "type": 1,
            "pos": [
                408,
                0
            "id": "keyboard button5",
            "z_level": 0,
            "mapping": [
                321,
                1,
                158,
                128
            "code": 18
            "type": 1,
            "pos": [
                138,
                137
            "id": "keyboard button6",
            "z_level": 0,
            "mapping": [
                641,
                1,
                158,
                128
            "code": 16
            "type": 1,
            "pos": [
                276,
                137
            "id": "keyboard button7",
            "z_level": 0,
            "mapping": [
                801,
                1,
                157,
                128
            "code": 31
            "type": 1,
            "pos": [
                415,
                137
            "id": "keyboard button8",
            "z_level": 0,
            "mapping": [
                961,
                1,
                157,
                128
            "code": 32
            "type": 1,
            "pos": [
                139,
                275
            "id": "keyboard button9",
            "z_level": 0,
            "mapping": [
                1301,
                2,
                421,
                128
            "code": 57
ChaliceChore
Hi all. I created an overlay for my G502 Hero mouse using Photoshop. I based my .json based off of the G502X one.
The basic buttons (LMB, RMB, Wheel) are working fine. But the Horizontal Scroll and G4 to G9 buttons won't work properly.
I looked into the .json file, and I am unable to understand the terms flags and type. Is there a proper Wiki where these are explained and listed?
Also, I reckon code refer to keycodes. I checked out the referred uiohook.h file. Are there keycodes available for the mouse buttons G6 to G9?
Yourii
Could you add the ukrainian translation for the plugin?
I prepared the translation`s file.
  • uk-UA.ini.zip
SketchMan3
I installed the OBS plugin and am using the xbox preset. But it's only showing inputs for the LT and RT triggers and none of the buttons.
bulieme
Hey, would you willingly like to add a touchpad support? for synaptics driver and such? it will be helpful if this plugin has that.
HotshotHenry
Hi there. I'm looking for some assistance setting this up for a joystick and racing wheel. Would this be possible here?
Saveforth
I'm getting an OBS crash after about an hour or more of usage. The crash logs suggest a memory access issue (c0000005). This happens with OBS running as administrator and no other plugins installed or enabled. I'm running both the newest version of the plugin and OBS, I really like this plugin, not requiring an extra application/window open for overlays is super nice, but currently I'm having to run OBS in safe-mode (running without the plugin) or OBS crashes, throwing me out of whatever game I've currently got full-screened.
If you have any idea how to fix this issue I'd love to hear it.
  • Crash 2025-03-22 17-40-43.txt
TAOTAO_okashi
Hey! Your overlay project is so cool! I've made my favorite texture based on the preset you gave me and applied it to OBS recording, but I encountered some problems.
Could you please inform me of the corresponding code when mapping keyboard keys? I've attempted to create a mapping for the arrow keys, but their value reached 0XE04D, while the code value in the mapped JSON file is 57421. This value is even greater than the sum of all other key codes. I'm not sure if this is the reason why only the arrow keys have no response when used in OBS. It clearly works well in io-cct. Or perhaps the arrow keys are not yet supported?
The following is my json file. I used wasd, numeric keypad 456, right arrow key and the enter,(right arrow key for jump, a Ergonomic design!)
RubixCube192
Can someone help me? I am trying to use MechVibes with OBS Input Overlay, but everytime I load it, the overlay just stops working. I am not sure how to get them to work together. I've been searching for hours.
SkyExploreWT
@univrsal Hi ! I don't know if you can, but would it be possible that you make for me a configuration ? I'm not smart enough to really understand how the config works, and everything's else. If it's possible, I would like to have ESC, BACKSPACE, LEFT-SHIFT, Z, Q, S, D and M. I would like to have it in this order if possible. If not, is there an AZERTY configuration file ?
TheyNay
Hi everyone, new user of Input Overlay here
I didn't quite understand how to edit and I'm shit at that type of thing anyway
The picture attached is basically my keyboard layout and I can't switch it for QWERTY for gaming
Does anyone have a Colemak config for Input Overlay, at least a config of the left half displayed there ?
And if no one does, could someone do one based on the original wasd-extended preset?
sori
Hi, these are great overlays and just what I've been needing.
However, the input history appears when typing:
A+B
C
D
E+F
Can you make it appear as one single element when typing like this?
"ABCDEF"
Monody
Has anyone created an N64 overlay for this plugin?
I made one in a pixel art style for myself. It's designed for use with an adapter that interprets the c-buttons as the right analog stick, and it requires chroma keying out the black background if you want to use it as an overlay.
  • N64_Pixel1b_x8.zip
Monody
Any chance of the Flatpak release being updated so the plugin can be used on Bazzite where Flatpak OBS is the only option?
