Melody Monitor
Melody Monitor 1.4.0
This does absolutely nothing but show a little pink note icon in activitybar. :P
Settings shows nothing but a near empty textfile. Open in browser attempts to show something 127.0.0.1 (wich does nothing cuz that is just the IP for any computers network card LOL)
I think this plugin is either not a finished one, or a buged one, or a hoax/practical joke.
I am still looking for something that can display song title played by a skinned VLC (Tuna does not work, it fails to read status from a skinned VLC). SMD wich I was previously using, no longer works either - probably because I am now running Windows 11 Pro, contra what was available back in 2014 when the SMD tool was uploaded here.
The search goes on for a simple no-nonsense tool that displays the title of what VLC is playing... And since VLC is playing a stream .pls file, not local music... Well. It's proven to be difficult.
gives me a unhandled exception in script
This is the first plugin I have found that will display local files of Apple Music... I can kick iTunes and its blinding UI to the curb finally... Though I would like a little more customization if possible? I know CSS so it looked simple when watching the video, but it seems a lot of that has been removed as of the current version? I couldnt get it to work...
The goal:
So Id have to be able to change art size, hide card/border/shadow, control font and sizes, move album to a 3rd line... I may even
be able to make my fire graphic in B&W, then make the progress bar color it orange as the song reaches the end... If I had control
over placement and stuff...
If something like this is already possible and im missing it, please let me know. As for how yours is displayed above, it only
seems to do that if the band/album line is long(might be the weird size I have it set too), does not scroll like a long title, at least for me.
Oh also, say music is playing, if you load a youtube vid, or a twitch stream, it takes over the card... Would be cool if there was a way to filter out unwanted programs... But im sure thats difficult.
Done, couldnt pull off the fire progress bar so I made it small and put it under the album art. Kinda a pain to impliment, but it works, and dark itunes interface... I figured out where the html files were, just have to overwrite them everytime I restart MM.
Have you tried using VLC’s built-in HTTP interface or enabling the web interface to pull song metadata from the stream, and if so, does it still fail to show the title under Windows 11 Pro?
Added mod support. Try creating your own mod and publishing it on github.
Try new GUI version
Hey ! Would love to use your plugin to show the music playing locally on my computer. Sadly I have an error when I try to run the exe, could you help ? I tried installing a prior version, same problem.
Hello @SuperZombi
Firstly, thank you for your work.
Unfortunnately Melody Monitor doesn't work for me I'm on OBS 32.0.4.
When I try to go on the URL adress http://127.0.0.1:8000/ I have a White page with nothing. And when I'm try to go on http://127.0.0.1 I have simply an error message that talk about firewall and connection.
I verified all my parameters on my internet box and on my PC (including firewall, antivirus and any program who can block it) but nothing resolve it. When I installed it I have an error message about script. Tell me if you need more informations ?
I really expect to use it one ASAP :D
