aRCANUM
Great news, hae you been able to reproduce tha bug with grouped audio sources with filters ?Yep, planned, since I got a device to test it!
No ETA yet
No ETA yet
Nope, I'll probably give you a verbose version to identify the bug.Great news, hae you been able to reproduce tha bug with grouped audio sources with filters ?
Select LoopBe1 as MIDIfoward device in MIDIControl.Hi o/
I would to know if it possible to have send informations of the same MIDI keyboard to 2 differents apps without using my keyboard (with letters, like MIDIKey2key do I think). I looked for a solution during the last 2 days but I can't find anything...
LoopBe1 need another software to work (I think because when I select it in your app it do nothing) and the majority of music software have options to do that.
So maybe someone asked it before (but I found nothing or maybe I do something wrong). In any case, your app is very good :D
Update :
First release on a working Feedback for APC Mini (only for audio atm)
Scale for audio in OBS has been changed
Bugfix :
collision of key and sliders => You probably have to re-setup all you MIDI keys
Nice. thanks man. ;)Scale for audio in OBS has been changed
Should be available soon in MIDIControl, as a such feature exists now in obs-websocket !With the current OBS API, there is no such mecanism.
Only a " obs_transition_get_time " function, but I can't remotely change the current position of the transition.Search — OBS Studio 32.2.0 documentation
obsproject.com
Will be available soon, as it's in obs-websocket !Yeah another request I have would be to be able to trigger the 'Play', 'Stop' and 'Restart' triggers that can currently be triggered by hotkeys on Media Sources.
Yep, next release I hope !Is it possible to add a set scene to preview option for studio mode?
Features :
- Preview Scene (like Switch Scene), for Studio mode only
- Media Play/Stop/Restart for Media Scene Items
- Transition manually using slider/knob
- MIDI Feedback for some OBS actions (only for APC Mini at the moment)
You have to upgrade your OBS Websocket to version 4.9.0 at least ( https://github.com/Palakis/obs-websocket/releases/tag/4.9.0 )
Great Plug-In. Is there any chance to control with a midi slider the transitionslider in studio mode in the future ? that would be awesome.
Done in version 1.5.0.0Is it possible to add a set scene to preview option for studio mode?
Do you remember the version of MIDIControl you had before updating ?Thanks! The preview works great! Except I had to update my websocket and OBS and now the sliders are not working. I tried deleting and re-adding them or modifying the knob assignment (Behringer X-touch mini) but neither the knob or the knob press are doing anything although the app sees the input. Anyone have any ideas?
Features :
- MIDI Forward IN & Out, using loopMIDI preconfigured. You can now forward MIDI Message to another 3rd party app, and activate MIDI Feedback in the 3rd party app. Supports only APC Mini.
- No more configuration to activate MIDI Forward.
Bugfix :
Crash for some configurations when using soundboard.
Should be OK with latest version 1.6.0.1Okay, so MIDIcontrol crashes any time I try to use my MIDI to play a something using the soundboard function. About 1/4 second plays and then it just does a hard crash. No other program is having issues. All OBS functions work great. All audio files are .MP3. The soundboard function is currently useless. Any fixes? Is it the file type? It's still a great program to do scene changes and control audio, but half the program is currently not functioning at all.
