Resource icon
Move Workflow 1.2.1
DuhBuhHuh
DuhBuhHuh submitted a new resource:
OBS Move Workflow - Build visual workflows to control, sequence and determine when Move Actions run.
OBS Move Workflow adds a visual workflow system to OBS Studio that works alongside Exeldro's Move Transition plugin.
Create workflows from Trigger and Action nodes and control when actions run, what runs at the same time, and what happens next.
Action nodes can run Move Action, Move Source, Move Source Swap, and Move Value filters, or change the active OBS scene. Each action can have its own Start Delay, Duration, and End Delay.
Workflows can be triggered using the Trigger Workflow...
DuhBuhHuh updated Move Workflow with a new update entry:
Move Workflow 1.2.0
Move Workflow 1.2.0
- Original workflow filter settings are no longer modified/restored
- Filters are now duplicated at the start of a workflow and destroyed when the workflow ends.
- Easing overrides can be applied to nodes without modifying the original Move filter's easing settings.
- Improved simultaneous workflow action execution.
- Improved searchable scene/source/filter selection.
- Added workflow execution debugging and lifecycle handling to logs.
- Continued separating workflow...
Bug Fixes and improved workflow handling for invalid nodes
Various bug fixes and flow handling
  • Added the current plugin version and a link to the latest GitHub release in the editor.
  • Added missing node handling and improved node connection logic.
  • Nodes that have invalid or no filters attached appear red.
  • Links to non-existent nodes are visible via a trash can for easy removal from the workflow.
  • Fixed the workflow not running when the filter a node references no longer exists.
  • Nodes linking to non-existant filters are now...
