Multi-window game's
ThIsLinked
Good afternoon. Search the Internet, if somewhere explains how to make multi-window, it is only on simple windows. I capture the game through "Game capture" method "Capture specific window". The image in the OBS preview appears, everything is fine. But when I try to add the same source again to overlay the second on top of the first one, the first source stops producing an image.
Is there a solution? I attach an example of the result, which I am trying to achieve (the example made through a photo editor).
I apologize for the unnecessary created topic. I found a solution: On the first source, select "Copy" from the context menu and click "Paste (link)" on the empty in the "Source" window. It will create a link. This element is independent of the original. That's what I need.
Worked demo: https://youtu.be/5hPucL_mM7Q
To the moderators: I suggest that you don't delete this thread, but link to it if such an issue arises.
