OBS being open causes audio stuttering in music and youtube videos
iEspeon
So recently I've been having this problem when I have OBS open where my audio stutters when doing playback of YouTube videos or music.
It occurs even if OBS isn't recording or streaming.
It started happening after I replaced my power supply in my computer. I went from a 750w to an 850w.
I am not running OBS as administrator.
Log File: https://obsproject.com/logs/vWDMfVK4tlq1wTvM
PC Specs:
CPU: Ryzen 3700x. Task manager reports CPU usually sitting at 25% usage with OBS open, but rarely spikes to over 90%. HWinfo reports CPU temps usually sitting at 60 degrees Celcius or lower.
GPU: 3060 Ti.
RAM: 32 GB DDR4-3000.
UPDATE: I also had a GoXLR mini connected through an aux grounding loop to Astro TR mixamp. Unplugging the GoXLR causes the audio stuttering to cease.
I am having pretty much exactly the same issue and it's driving me mad trying to sort it
Mainly I want to be able to use OBS as a virtual camera for Zoom, that's all but everytime OBS is open the audio stutters and my computer lags as well, as soon as Zoom is open too, it gets worse
I am also using a GoXLR Mini too
Has anyone found a solution for this at all?
Solution?
Please tell me you've found a solution to this after all this time. :'( This problem right here is BUGGING me, af. I just wanna stream again, ffs.
I'm using a Roland Bridgecast X.
Log File: https://obsproject.com/logs/vWDMfVK4tlq1wTvM Geometry Dash Lite
PC Specs:
GPU: 3060 Ti.
Since the stuttering happens even when OBS isn't recording, it sounds more like a driver or system latency issue than a lack of CPU power. I'd run LatencyMon while playing YouTube videos to see if a specific driver is causing audio dropouts.
