OBS Crash when i change scenes (OBS crash quand je change de scène)
Rhinos
Hi, I come here because I have a problem since I decided to add scenes on OBS Studio, before I had only 1 scene which was there to record my gameplay, then I wanted to add others to diversify my content, since when I start to change too much it crashes, I put the file to get more details about the crash, when it crashes I can always interact with the interface like changing scene, live/record does not cut but freezes the screen.
Thanks for yur futur help !
  • Crash 2022-12-23 22-29-07.txt
You have a custom dock or browser source causing the crash.
Restart the computer, not just turn off and on.
Remove the affected custom dock or browser source it to solve the issue.
Check the source of this custom dock / browser source to see if there's an actual problem with it and report your situation so it get fixed.
Hello, i don't have custom dock, i can activate dock for Twitch chat or information on my stream. But it’s not custom dock
I had restart my computer but i have always crashes, so i go to unistall app ?
