OBS gives crash when closing..
prgmitchell
News: I tested the stream right there and there is actually a big problem: not only does it crash when I close it but also my game window is simply no longer streaming and that on the other hand it doesn't seem to me that it is a plug-in, suddenly now I can't stream at all until the problem is fixed?
If something has changed you'd need to post a new log, the crash logs you posted before were all crashes from the streamlabs plugin.
Kinnison27
No I didn't change anything, I'm sending you today's log for the same problem, so how do I uninstall the streamlab plugin?
  • 2024-12-09 12-08-00.txt
Kinnison27
Well... I uninstalled all the streamlabs plugins and now it doesn't crash anymore when I close obs, it's very annoying because now I can't use streamlabs anymore but I'm dealing with it, except that the problem with the game screen not showing anymore I still have it, now I don't know what to do I'm desperate, it's not even a plugin the game screen is a basic obs thing! So what do I do?
For me I blew the app away then re installed everything ( 2 Cameras and approx. 15 scenes in PTZ Controls . Suspecting the PTZ Devices plugin but not sure . Not sure if I'll ever know as We have a simple small installation at Church ! 2 PTZ 30x Cameras , an audio channel from our audio controller into Black Magic design Mini Pro with OBS Studios and I use the Software for Black Magic Design and can do a soft scene change with a delay of 8 seconds on the cameras
No, it's not. I have none installed.
No log file, no crash report. Both from the same time.
If there's no crash report, then OBS didn't crashed but something else caused OBS to close. Please open your own thread explaining what happened posting/attaching the needed files.
