obs-gstreamer
obs-gstreamer 0.4.1
Tuna
It is always recommended to compile your own version to the GStreamer SDK of your choice. The pre-built one is compiled to the SDK installed via macports. Copying other runtime files around may or may not work.
When compiling on your own the correct locations should be set in your final library. It will also build for the native architecture of your system (x86_64 or arm64).
rdagijones
I am reading and trying to get a gstreamer instance in OBS working from an IP camera but keep getting a black screen. Here are some stats:
  • Windows 10 pc
  • gstreamer installed
  • path variable is set (checked this on this forum and youtube)
  • plugin installed on OBS and get the test patern.
  • I can get an rstp stream from VLC with the following URL
rtsp://admin:pass1234@192.168.1.81:554/ch0_0.264
I am fairly certain that my pipeline is the issue but I cannot figure it out. Here are some examples of what I have tried.
uridecodebin uri=rtsp://admin:pass1234@192.168.1.81:554/ ! queue ! video.
rtspsrt location-rtspt://admin:pass1234@192.168.1.81:554/ch0_0.264 ! rtph264depay ! h264parse ! nvh264dec ! videoconvert ! video.
rtspsrc location=rtspt://admin:pass1234@192.168.1.81:554/ch0_0.264latency=100 ! rtpjitterbuffer latency=0 ! rtph264depay ! h264parse ! d3d11h264dec ! video.
Attached is a screenshot of Video settings on the camera (if that helps).
Any suggestions on how to troubleshoot this on a Windows PC?
Tuna
.264 but H.265 in profile would make me suspicious. But as always - make it work with gst-launch-1.0 first. If that does not work it is not a fault of the plugin.
