OBS Transition Matrix [Discontinued]
OBS Transition Matrix [Discontinued] v1.0
jbarradale
As of this latest Windows Update, Transition Matrix no longer works. It seems the transitions always use whatever is shown in the drop down list under scene transitions.
Maxcrazyvolley
Ciao ma il plug-in x mac non c'è? Nella panoramica è dato come disponibile x mac ma non lo trovo...
shaolin
Joefisx20s
Vintendo
Does anyone know where Transition Matrix saves your presets?
I updated to use the new one and did not like it and a few things stopped working.. Seems that all my Settings are gone .. Where does Matrix save its config File for My old transitions ?
Vintendo
Seems that all the transition Settings are gone. I have a back up of my obs where does Matrix save its config For the transitions ?
ErgoDTerror
Sorry for the dumb question but how do I uninstall this correctly? I tried to get rid off the files from my OBS studio folder but when I open OBS again a mini window appears sayign that I need to update transition matrix.
