Resource icon
Pthread Text 2.0.6
norihiro
I suppose for Windows this plugin can not be expected?
I'm sorry I tried to build for Windows 2 years ago but I almost gave up.
For Windows, I recommend to use Browser Source. it can load from local file, and CSS can specify nice outline, shadow, etc.
Nutri_
Hello! I've installed the ARM version on OBS 28, but somehow the text is never showing. What could this be?
I tried different fonts, sizes, color, width/height changes, tinkered with every other settings.
norihiro
View attachment 86280Hello! I've installed the ARM version on OBS 28, but somehow the text is never showing. What could this be?
I'm sorry that I have never tested this plugin on ARM but just build the same source code for ARM. So far I have no idea to prepare debugging environment for ARM. PR would be welcome if someone find the way to fix the bug.
Nutri_
No problem!
If there is something I (as a non-programmer) could provide to you that would help debugging, just let me know what I can do.
Spectr20
Browser Source has a problem, when saving a file, the data in the OBS is not updated
norihiro
No problem!
Could you provide a log file?
I just got similar issue on Ubuntu and it's reporter shows a log line below. If the same line is logged, it would be helpful.
[obs-text-pthread] Cannot load '(null)'
norihiro
norihiro updated Pthread Text with a new update entry:
Pthread Text 2.0.2
This is a major release to support OBS 28 and to drop supporting OBS 26.
Changes in 2.0.2
  • Fixed library dependencies for OBS 28 on Ubuntu.
(No changes for Windows and macOS users. No changes for OBS 27 on Ubuntu.)
Limitation
  • Not all binaries are not tested.
    • Version 2.0.0 for Ubuntu is tested on Ubuntu 22.04.
    • Binary package 2.0.0 for macOS is only tested on Intel mac.
  • No Windows support due to...
kjorteo
Hello! Thank you so much for this plugin--as a Linux Mint OBS user who's been limited to the FreeType2 text source options instead of GDI+, this plugin is beautiful.
One question... is there a way to have the text in a gradient of two colors, like the "Color 1" and "Color 2" options for the standard FreeType2 text sources?
Rabbit95
Are there plans to bring it to more distros like rpm package for fedora or flatpak? Can't You just provide .so file?
norihiro
I'm interested in rpmfusion for Fedora and CentOS, and also Flatpak. However, I don't have the milestone to achieve that. I'm sorry that I don't have enough time to make many systems.
I'm mainly developing on Fedora. The code should work if you build from the source.
norihiro
Pthread Text 2.0.3
This is a bugfix release for macOS on Apple Silicon.
Changes in 2.0.3
  • Fixed crash and issues that nothing was rendered on Apple Silicon macOS.
  • Added RPM packages for Fedora 36 and 37.
(No changes for Windows and Ubuntu users. No changes for OBS 27 on macOS.)
Limitation
    • Version 2.0.2 for Ubuntu is tested on OBS 28 on Ubuntu 22.04.
    • Version 2.0.3 for Apple Silicon mac is...
norihiro
Pthread Text 2.0.4
This is a hotfix release.
Changes in 2.0.4
  • Improve messages in log.
  • Fix code format.
  • Fix deprecated code in the build flow.
(There is no changes in behavior except the log message.)
Limitation
    • Version 2.0.3 for Apple Silicon mac is the latest tested package.
    • Version 2.0.0 for Intel mac was the latest...
I did what you said and it didn't show up in OBS. I first used the installer and the did it manually. Intel iMac OSVentura OBS current. Any help would be appreciated. Thanks.
norihiro
Could you share your log file of OBS Studio and/or a result of this command "ls -R ~/Library/Application\ Support/obs-studio/plugins/obs-text-pthread.plugin", which should print how the plugin is installed?
Thank You for your quick response! I followed that path and the folder was there. Then I analyzed this current file. https://obsproject.com/logs/IK4Zh5ZP9lBJjGty
Hope this is what your looking for. Thanks so much!....What should I be looking for and where? Is it called pthread or something else? Thanks.
norihiro
Pthread Text 2.0.5
Changes in 2.0.5
  • Fixed the plugin was not loaded by OBS Studio >= 30.0.0 on Intel mac.
  • Added RPM packages for Fedora 39 and 40.
  • Dropped RPM packages for Fedora 36 and 37.
  • Updated macOS host version and GitHub action versions (This should not affect anything).
  • Support in-tree build.
(There is no change for Apple Silicon mac and Ubuntu.)
Limitation
  • Not all binaries are not tested...
norihiro
Thank you for providing the log. I realized the plugin started to fail from OBS 30.0.
The new version 2.0.5 should work. The direct links to the package are below.
obs-text-pthread-2.0.5-obs28-macos-x86_64.pkg (This should work with OBS 28, 29, 30, and hopefully 31.)
obs-text-pthread-2.0.5-obs28-macos-x86_64.zip
