Scene Grouping
HiImRaine
Hey guys,
I have recently found a workaround for a problem with NDI sources, which will constantly resize for unknown reasons when added as sources.
The workaround is that for every NDI Source, I create an individual scene, and use the scenes as sources then.
This in turn creates a new problem, namely that I have many scenes as "workaround" sources, and I wonder if it's possible to add the function to group scenes, like you can group sources.
Regards
Zero
