SceneAnchor
SceneAnchor 1.0.0
rockben
rockben submitted a new resource:
SceneAnchor - Folder tree for the scene list — folders live inside the scene collection and survive copy/rename.
Scene folders that stay put. Existing scene-tree plugins keep their folders in a side file keyed by collection name, so copying or renaming a collection loses the lot. SceneAnchor writes the tree into the scene collection's own JSON, the same file as the scenes, so it survives copies, renames, exports, OBS Studio updates, and uninstalling the plugin.
Requirements
OBS Studio 32.0 or newer, 64-bit. Builds are provided for...
Hello. I am going to try the plugin. Looks great, but I do not understand how to install it on windows. In which subdirectories goes bin folder and data folder?
bin/64bit folder is copied to obs-plugins\64bit?
for data folder content I should create scene-anchor folder in data\obs-plugins?
I install the plugin, tried it. It looks really promising, but when I started to make nested folders it keeps crashing.
I appended crash file. Maybe it help. At the moment I uninstall the plugin, cause I need the obs running
