Skipping some frames every second, why is that, is there a fix?
Melubo
so right now I am very okay with the quality of my stream, no pixels no anything, for 864p it looks good imo and I can stream with constant performance and bitrate, but i noticed that the 60fps look a bit like 50fps and i also noticed when opening videostatistics in the VOD (in twitch) that I always skip 2-3 frames per second, is there a setting that I am missing that fixes it?
https://www.twitch.tv/videos/2033609990?filter=archives&sort=time (thats the video)
thats my log:
on the pics down there u can see my settings
or am I wrong and the skipping frames in the twitch videostatistics show the viewer that is skipping these frames, not the streamer for the viewer? what do u think, share ur thoughts (basically two issues, frames go from 65 to 55 every some seconds changing not constant 59 or 60 and i skip frames)
thank you, fellow OBSers
Doubtful, those settings change basically nothing with your 3080TI. Changing the re-fresh rate of your monitor from 280 to 240HZ while using OBS will be more effective & may even do away with your GPU overload.
21:13:58.143: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 9 (0.2%)
Similar set-ups, not sure about your BIOS since your stuttering is more constant than random but there's info here you may need.
I know nothing about this but I do know that MS Defender will not cause issues with OBS.
20:43:24.986: Avira Security: enabled (AV)
20:43:24.986: Microsoft Defender Antivirus: disabled (AV)
