spectralizer
spectralizer v1.3.4
Monagii
Good Afternnon, I am trying to use the spectralizer on my obs, but it isn't appearing for some reason. I use a windows computer. Can you help me?
djnokk1
Hello - I have updated with homebrew on my MacOS but it still doesn't work after successful install on my machine. Any suggestions?
I really enjoy using this plugin in live streaming, but I'm not sure if you're still updating it
I have localized this plugin in Chinese. If you are still updating, you can place the localized files in Github or the next update
Thank you!
  • spectralizer1.3.4 - zh-CN.rar
Danubio
I am download the source version and the Windows version, but there are only 64-bit and 32-bit options. I need a version for an Orange Pi Zero 3 that is working on the armhf architecture. If you can help make it work on the arm architecture, thank you very much. It would be a great advancement for the project, as there are many ARM-based boards like Raspberry Pi, etc.
Hardware: http://www.orangepi.org/html/hardWare/computerAndMicrocontrollers/details/Orange-Pi-Zero-3.html
I'm tinkering with the OBS plugin that I used to localize in the past, initially there was a lot of machine translation and some untested text, now I've gone further with this plugin to bring the localized text more in line with the functionality.
I'm not sure if you will continue to update this plugin, if you will continue to patch or enable this project, please carry the Chinese localization files with you until the next release.
I have localized the plugin to the latest version: 1.3.4
  • zh-CN.rar
