Sports Scoreboard for OBS on macOS – Live Score Overlay & Scorebug
Free Sports Scoreboard for OBS on macOS – Live Score Overlay & Scorebug 1.25
Hi. Thanks for you great plugin.
I have already used it a few times to display the scores live at a table tennis tournament and also to embed them in a live stream. i love it.
I always control it via my streamdeck. I can easily assign all functions that have an assigned hotkey or can be called up in the menu.
I am missing two functions.
Firstly, the swap home and away team function is only available as a button and not as a hotkey or menu item. Is there a way to access this function via a shortcut?
Secondly, is there a hotkey to reset individual scores? So the same as 'Reset all stats' but as an example only the goals?
Should all counters be reset at once or is there a separate reset for goals, shots, etc.?
Hi bro,
Could i customize your app to livestream Pickleball or Tennis?
I want to customize like that bro.
And do you have any plan to discount for Black Friday ?
Hi bro,
Hello!
You can partially repeat it (players' names, and three separate counters for each player/team), but some data will have to be managed manually in OBS itself.
ScoreBoard has three separate counters for each team (goals, shots, points) and one common one (period). In the picture from scorebug I see that 4 counters are used (one before the players' names and three after the names). Plus there is some kind of mark (green circle), perhaps indicating whose serves are currently in tennis, such a function is also not in the program.
Text fields at the top and bottom can be statically added to OBS, they most likely do not change during the game.
P.S. I will look at sports scoreboards for tennis and add another counter for each team if it is needed there. I did not think that somewhere more than 3 counters for each team would be needed.
