STREAM 720P / 60 FPS , image blurry
RyuSolo
Hey ,
I'm trying to config my OBS settings but i always the video is always blurry
PC SPECS :
CPU - AMD Ryzen 5 2600 (3.4 GHz)
GPU - AMD Vega 56
RAM - 16 Gb
https://www.twitch.tv/videos/667025188 - here's a clip of how it looks..
Can you help me fix this ?
Thank you!
Kind Regards,
Ryu
by "blur" I'm pretty sure you mean pixelation
depending on your internet upload speed, you can use a higher bitrate (I have an upload speed of 11-12 Mbps and use a 15000 bitrate)
try using a higher bitrate (increase it by 500-1000 every time and test it) until it will eventually be too high and your video will look like a slideshow, then lower it a bit and there should be no/very little pixelation
i want to stream , twitch only allows 6000 bitrate max
why should i put my output resolution in 1080 if i want to stream in 720 ?
Suppose your avatar was 1920x1080
Suppose we re-scaled it to 1280x720, it would like this:
This is going to happen whenever you downscale images/videos. Edit: This example is a best case scenario as the new image was saved as a png which is lossless.
I'm pretty sure you're able to stream at a higher bitrate than twitch allows but it might be slower for your viewers depending on their internet speed but I might be wrong
i think i understand now why it's pixelated , because i have a 1920 x 1080 screen watching a 1280 x 720 stream
