StreamAssistant
StreamAssistant
prgmitchell
prgmitchell submitted a new resource:
StreamAssistant - Host, join, or connect locally to an OBS instance.
StreamAssistant allows you to either connect locally to an OBS instance or host/join a session allowing remote management of scenes, sources, and settings using websocket. This tool uses a secure WebRTC p2p connection between the remote browser and the browser connected locally to OBS while a signaling service only helps the browsers establish that connection where commands/state changes/previews travel through an encrypted WebRTC...
