Teleport
Teleport 0.7.7
Hi really great plugin, normally works flawlessly. However the last 2 days there's a gigantic delay on the encoding PC, does anyone know how to fix this? I've reinstalled windows, OBS & the plugin to no avail. Nothing has even be changed for it to stop working.. Thanks.
My wife and I game together and I want to switch to her POV on stream here and there. I have Teleport working on our LAN connection, but when I make the scene with her screen visible, it lags like crazy. It also repeats anything I say in my mic a few seconds later for some reason. There's nothing extra in the audio mixer and I can't make sense of it. Any suggestions would be greatly appreciated!
Good plugin which mostly works.
Anyone know how to delay the incoming teleport audio as my video seems to be delayed slightly (the audio comes through instant but video lags) ?
This is an amazing Plugin, however I still trying to reduce the lag between PC 1 (Gaming PC) and PC 2 (Streaming PC) there is a delay on what I do and what it streams to twitch, Its not huge but wondering if it might be internet related:
Download 30 MB
Upload 7 MB
Gaming PC Teleport at (45 Quality) (Ethernet Wired connection)
Streaming PC (2.500 kb/s to twitch) (Ultra Fast) (Baseline) (Skip 2 ms) (Ethernet Wired connection)
Again not a huge delay but I noticed it is anywhere from 3-5 secs when working properly and laggy (9-25 secs) (This is the issue trying to mitigate the chances of happening).
Hoping for some positive feedback and not someone telling me useless stuff like "Get new ISP" or "Get better internet" (Right now can't not due to monetary issues but location issues, Argentina SUCKS so only ISP that comes to where I live is this 1 and they are awful as it is......)
Hello everyone, 2 PCs, 4 network cards - 2 for the Internet, 2 for the Teleport signal and direct connection, configured according to this guide: https://youtu.be/8ESrXtXzynM?si=S4hgAHXd4zgMjaO6
The task is to unload the Internet channel and have the signal go separately on a 2.5 Gb channel, where 90+ quality will easily work. But the problem is that the plugin sends the stream to 2 channels at once. (On the first screenshot 2 channels are loaded with 400+ Mbit, on stream PC OBS the source IP of direct 2.5 Gb connection is selected) If I select my regular Internet connection as a source in OBS, it is loaded twice as much - 800+ Mbit. But if I remove the internet cable from the gaming PC, the stream goes normally through a separate channel, 400+ Mbit. How can I make the plugin transmit the signal via a selected separate channel and not load the Internet channel?
I'm running Ubuntu Studio 24.04 LTS and OBS Studio 30.2.3
I created plugins folder in ~/.config/obs-studio and nothing happened.
I found a folder called plugin_config and figured out it being the roght folder.
Copied the plugin folder in the plugin_config.
Started OBS and it crashed immediately and repeatedly.
Then I deleted folders .git, .github and img.
Ta-daa! Seems to work. Will try streaming when back home.
So the complete installation on one ubuntu distro:
1.
sudo add-apt-repository ppa:obsproject/obs-studio
sudo apt update
sudo apt install obs-studio
2.
git clone https://github.com/fzwoch/obs-teleport.git
3.
copy folder ~/obs-teleport to ~/.config/obs-studio/plugins_config
use whaterver method of copying pleases you
4.
delete folders .git .github and img from the folder ~/.config/obs-studio/plugins_config/obs-teleport
use whaterver method of deleting pleases you
5.
enjoy
1.
sudo apt update
2.
3.
4.
5.
enjoy
Sorry, nothing here makes sense. "plugin_config" is not the correct directory for a plugin installation. The git repository itself does only contain the source code, not an actual plugin.
How do I uninstall this plugin? I think I removed all the relevant folders from Appdata and checked the OBS folder but even after reinstalling OBS I still see Teleport in the menu.
Ok, it seems it installs itself in ProgramData too.
Well.
This was exactly how I did it and it works.
I do not know why it's plugin_config. It just is. Maybe they changed something in the 30.2.3 version. Maybe it's something OBS needs to configure at launch.
The obs-browser which came along with the OBS itself was already in that plugin_config.
I have one other plugin in plugins folder and it works from there.
And no. It is not a source, but the actual plugin in the git as it does not need to specifically be installed. Just copied. The same way as with Windows version. Just copy paste. Even the windows installer versions do this. Paste the contents in folder. Nothing more.
Just look in the git package. There's absolutely no compile or install related files or sources.
Of course some other plugins need compiling and such, but after that it's just copy and paste.
Well.
The documentation at https://obsproject.com/kb/plugins-guide clearly states that the installation directory on Linux is ~/.config/obs-studio/plugins.
Check the listing of the your plugins_config directory.
$ find .config/obs-studio/plugin_config
.config/obs-studio/plugin_config/rtmp-services
.config/obs-studio/plugin_config/rtmp-services/twitch_ingests.json
.config/obs-studio/plugin_config/rtmp-services/services.json
.config/obs-studio/plugin_config/rtmp-services/package.json
.config/obs-studio/plugin_config/text-freetype2
.config/obs-studio/plugin_config/obs-teleport
.config/obs-studio/plugin_config/obs-teleport/obs-teleport.json
.config/obs-studio/plugin_config/obs-websocket
.config/obs-studio/plugin_config/obs-websocket/config.json
These are all configuration files - as the directory name actually implies. No plugins here. (They actually have a .so suffix)
And again: Cloning the repository by itself accomplishes nothing. There is only source code in there. No binary code that OBS could run. You are supposed to download the zip package from the "Release" section which does have compiled binaries and also includes installer scripts for several platforms.
Hello, I have a problem when using the teleport plugin, does anyone know why it only works with a Wi-Fi network but when I connect the same computers to the same local network but with an Ethernet cable, the teleport stops working
Running OBS Studio 30.2.3 on 2 Windows 11 PCs. Receiver (Streaming) PC cannot detect Sender (Gaming) PC. I have Teleport enabled on the Gaming PC (Identified as 'Content PC') with no port specified. When I add a Teleport source to the Streaming PC and click the refresh button, no sources are detected. I have also added inbound/outbound firewall rules to both PCs for OBS Studio to allow TCP and UDP traffic on private network. Are there any known issues with the current version of OBS Studio? Am I missing something that is preventing the Streaming PC from detecting Teleport sources?
EDIT to this my apologies this plugin runs fine when used from 30.2 to 30.0 while both using teleport 7.2. I simply had to install myself, into my steam/common/obs folder as I downloaded from the Steam Store; and feel like a goof for it.
Thanks so much Mom and I had a blast screensharing!
Issue
My laptop OBS Teleport is not detecting my gaming pc.
Current setup
laptop is my streaming device - Connected Wi-Fi
pc is my gaming device - Connected Hardwired to my orbi.
Troubleshooting.
- I made sure my teleport on my gaming pc is enabled.
- Laptop and gaming pc firewall is deactivated.
- Restarted my laptop and gaming pc.
Im assuming my laptop has to be connected hardwired so it recognizes my gaming pc? Hopefully someone can help me with this.
Hello It would be cool to be able to separate the main sound and the music on Spotify for example, I tried with 2 teleports and 2 obs but not possible.
