Tuna
Tuna v1.9.9
univrsal
The user script has to be adjusted for the new design.
Edit: Update to version 1.0.19 of the script.
Ketza
It says version 1.0.19 but its not working.
anything to do in OBS, too?
SomeBeardo
Is there any way (w/Tuna or maybe something extra like StreamerBot, etc) to get rid of the " - Remastered 20##" text that some songs have?
I know you can modify the total length of what's written to a text file, but it would be great to be able to trim out that specific phrase.
jenks_
Tuna seems to lose its connection to Spotify half way through my streams, and I need to re-open the login page and authenticate again for it to work. Is there anything I can do to avoid this?
Yoedog
I'm having an issue where Tuna is pulling info from the incorrect VLC Source. Instead of pulling the info from the current track it is pulling the background videos info. It worked fine before migrating to a new PC but I can't seem to find the issue. Any suggestions would be appreciated!
Pixelfox3
Check again the VLC sources in the config window. Go across all the scenes in the dropdown and remove all VLC sources. Then go back and add the one you want.
If you have both vlc sources in the same scene maybe moving the music one to a nested scene may help.
I would recommend you to try an external player (potPlayer and Foobar2000 are nice and customizable). But before changing all your setup make sure the problem doesnt happen.
slimehudson
I might be a little dumb, but I'm not sure how to configure the now playing text file. I created a txt file for Tuna to use but it only displays "No song playing", the txt file is empty, do I need to populate it with a list of every song I've added to the vlc source?
Hi - I usually use Tuna to play from Deezer but this has stopped working - I've resetted everything in OBS etc. and it's not working - as soon as I select Host / Receive port - that works with things like YouTube but just want it to work with Deezer! any help here please
I've tried rolling back OBS and reset Tampermonkey script - no luck
MySmile
Edit: It should work again with script version 1.0.20
Hi, much much earlier temper monkey script for browser work for YT and YTmusic, some time ago after I update obs from 27 to 30 ver and update Tuna to last ver + update temper monkey script, it doesnt work for YTmusic. I tried many way, but no result's. In console we got some data like 'title' (attached first screenshot), but seems that it didn't go to tuna, nothing changed in text files that i use (attached second screenshot), and after ones script stop work. Is script still work for YTmusic? Or it's only problem on my side? Any idea what i can try to do?
Thanks in advance.
Some solutions for Yandex.music, if it didn't work for you, try to change some settings in TEMPER MONKEY SCRIPT, like me, see the third attached screenshot below (BUT YOU DO IT ONLY ON YOUR OWN RISK!). But it's helped me.
petjo10
When I play a video in VLC-playlist the (Tuna) textsource is shown..but when i pause or stop the playlist the textsource hides.
Is it possible let the textsource never hides?
