Waveform
Waveform 1.9.1
Hi all, trying to figure out how to install this with macOS 26 and OBS 32. M4 Mini and I get this error on install.
Hey, just wanted to say thank you for putting this out there for us to use. Its a delight to play with, and I've been using an obscene number of duplicates to make a sound reactive boquet.
If anyone else wants to try making these, I make them as a separate Scene with just the waveforms, and add them into desired scenes as a Scene Source.
My settings for the waveform visualizer source are:
Display ModeCurve
Video Width X Height350 x 350
Log. Mirror. Radial. and Invert check boxesAll enabled
Deadzone0
Radial Arc3 petals=120 degrees 4 petals=90 degrees 5 petals=72 degrees
Simple EMA > Temporal SmoothiingInertia 0.63 with Fast Peaks enabled
Gaussian Filter set to 14.30Low cutoff =0 High cutoff = 17000
Floor -80 dbfs, Cieling -6 dbfs, Slope 3.87Gradient Ratio 0.98
for 4 petal flowers: Center-to-screen > Copy > Duplicate source > Rotate 90 degrees > Duplicate both sources and rotate 180 degrees.
for 3 or 5 petal flowers: Center-to-Screen > Duplicate > hand rotate with Snap to angles turned off > repeat per petal.
To make the center petals a different color, I Group all > Duplicate > Scale down > Center-to-screen > and then Apply a Color Correction filter to the new group.
To make a thin petaled or 6+ petal flower, make a 3 petal flower > Duplicate > Drop its opacity with a color correction filter > and rotate it about 15-30 degrees.
I styled this multicolored 5 petal after a Forget Me Not, but this would also work for a Sakura Blossom, Daisies, or Hibiscus with different color values. You could also Scale>Center>Rotate the Scene Sources to make a multi-layered Lotus, or spread them out on a stem.png to look like a Lily of the Valley!
Currently doesn't work on the Metal renderer for OBS, only OpenGL, on macOS Tahoe. I don't really know how much better the Metal renderer is, I can't find any actual objective discussion on it, just a lot of shrugs and PC master race piss-throwing on Reddit. ‍♀️
The plugin causes OBS to crash as soon as I add a Waveform source, and I have to restart OBS in safe mode and remove the source for it to work again. I tried the 1.8.1 and 1.9.0 beta, I'm on Windows 11 and OBS 32.0.4.
My bad it's another audio visuualizer plugin that causes the crash, sorry (I don't seem to be able to delete my message?)
Is there any way to show each individual bands like a 4-band EQ, had a project idea and needed to know?
I get an error after updating to the newest version:
The following OBS-Plugin could not be loaded: waveform
The OBS Log says:
15:40:01.696: Module '../../obs-plugins/64bit/waveform.dll' compiled with newer libobs 32.2
There is no OBS Version 32.2 available. The current Version is 32.1.2. Could this be a mistake somehow? Maybe forgot the .1 in 32.1.2?
The OBS Log says:
It was built against the 32.2 beta, please try 1.9.1: https://github.com/phandasm/waveform/releases/tag/v1.9.1
Sorry for the inconvenience.
Just a little note.... I had issues with my OBS not starting up unless it was in safe mode. When I followed your directions to uninstall old for new Wave it started up in normal mode. That was the last version. I haven't tried your last update though. I will soon. I'm sure it cleared up or fixed it Thanks Mac OS Ventura OBS 32.2. beta 2.
hey @Phandasm , is there a way to increase the width of this line?
and perhaps is there a site where we can find templates which are compatible with your plugin which have more effects?
