Resource icon
win-capture-audio v2.2.3-beta
RpRDraugr
Hey guys, I downloaded version 2.2.3 today but for some reason the only options I have are 2 drop downs, one for window selection and one for window match priority. I need the option to capture all audio except excluded executables. Is it a setting issue or a version issue? My obs is updated to 30.2.3. I linked a video that shows the settings I'm trying to get.
RpRDraugr
I swapped to 2.2.2 with a couple random resets and it fixed it
kslen
Hey there!
Just wanted to let those who has commented about audio dropouts know that there is a fork of this project. I've yet to test it, but as I'm absolutely terrible at remembering doing such things as follow up after testing and I get to that stage - here's the link to the repository which have merged a crash fix and made an attempt at fixing this issue: https://github.com/nyakowint/win-capture-audio
There's no installer, but it's easy to do update thing. Simply overwrite the existing files in C:\Program Files\obs-studio\obs-plugins\64bit\ with those found in the latest release zip.
This implies that if you haven't installed it, you'd need to grab the installer from bobez repository found here. :)
Now, I shall return to exploring many plugins all at once, hopefully also no longer having to tolerate the audio sync issue which has plagued me over the longest time with the official version of this plugin included with OBS.
Sevyu
Hello!
I donwloaded the Win Capture Audio plugin, so I can hear all my Desktop Audio but the applications I don't wanna hear on my recording (like Music).
I enabled the "capture all audio EXCEPT sessions from the selected executables". But now I got the problem, that my mic also is being recorded on this audio track. Is there a fix of how I can disable that, so my application I marked and my mic aren't heard in the rec? Thanks in advance!
CidGG
This plugin is a great tool; it's been very useful for me using Twitch VODs, thanks! The only issue is with Call of Duty Warzone, as it doesn't detect voice chat. Is there a solution for this?
Es una gran herramienta este plugin, me ha servido muy bien para usar el VOD de Twitch, gracias! El unico inconveniente es con Call of Duty Warzone, ya que no detecta el chat de voz, alguna solucion para este problema?
I'm curious about something that I've been seeing in this thread:
What do APK advertisements in here have anything to do with? Those who post these ads apparently don't understand how OBS Studio works, let alone what the plugin even does.
I've already done my part for these, which is reporting them to the mods.
And for the mods, bon appétit, mes amis.
--Katt. =^.^=
