MIDIControl - Control OBS, Soundboard, Twitch chat with MIDI Devices
Free MIDIControl - Control OBS, Soundboard, Twitch chat with MIDI Devices 2.0.1.0
That are the Monitor-Events from MIDI-OX
I got some light on the original launchpad, if i press the learn view, page, etc circular buttons the right circular buttons will light, and on the sqare buttons looks like it´s going to work but if i put another action i will get this, i´m only able to use one button on the new update
Make sure to name the keybind differently from an other already existing one
Is it possible to implement a feature whereby buttons need to be pressed and held (for a couple of seconds) before they activate?
My fat fingers have, on more than one occasion, caused me to accidentally stop a stream because I caught the start/stop button.
Hi, MidiControl is really very powerful and the possibilities are almost endless. But I'm having trouble configuring the Lower Thirds through it. As I understand it, it would be for HotKeys, but it's not working. Would anyone know what is the correct way? Thanks.
You have to setup Animated Lower Thirds by enabling the "brower source", the "control panel" and the lua script.
I recommend you to read the README.md of Animated-Lower-Thirds
yes, everything is installed. I watched several tutorials on youtube demonstrating. In OBS, Lower Third works correctly, the issue is in the “communication” with MidiControl. Because the other functions such as changing the scene, playing the media, etc., MidiControl performs faithfully.
Hello. I was just about to upgrade to latest version but I wanted to ask - should I uninstall the current version first? How can I save or retain the the note configs I have now?
Thanks for a GREAT Program!
Unless you upgrade from a very old version, just install over it, and it should work.
Config files are in %AppData%\MIDIControl
I can't get a handle on the separate Profile Feature. I checked the Profile .ini(s) in both folders and there is only one Note Off triggered scene listed.
Do we have to Delete and Start Over with each Profile?
Please advise.
OK - moving forward slowly - Save Icon does nothing. ENTER Key Return starts New EMPTY Profile
Love this program!
Hello everybody
i don't know if i'm right here? because I almost never use a forum :) Still hope for help ... Search solution OBS and Roland Go mixer settings. I've tried a lot but I just can't get any sound in the stream and I don't know why? Maybe one of you has an idea? Thank you in advance and if I was in the wrong channel I'm sorry :) Thanks for your help
I also posted this in the review but this might be the better place. One feature I would really appreciate is to add a delay to the transition. Now the midi signal is faster than my video signal so you see a the last slide for a few 100ms. Is it possible to set a delay in the program from the moment of incoming MIDI signal to sending the signal to OBS?
In settings, you can set a MIDI Delay.
Ok thanks I didn't now about this feature. But this would still not solve our specific problem. As some of the signals need to happen immediately to be correct. So I my perfect program would be able to set the delay per scene.
