MIDIControl - Control OBS, Soundboard, Twitch chat with MIDI Devices
Free MIDIControl - Control OBS, Soundboard, Twitch chat with MIDI Devices 2.0.1.0
Hey there, first off I wanna say thanks for this wonderful plugin! It has brought so much character into my work.
I'm here because i'm having issues getting MidiControl to work with the StreamFX plugin :c
The StreamFX filters show up in MidiControl, but it seems not all the parameters populate the dropdown list of options.
Plus none of the StreamFX filter parameters are changed by MidiControl, but other filters work fine.
Is this an issue on my end, or is there a compatibility issue between one of the two plugins?
Thanks for your time!!!
You have to manually configure there, as explained here : https://obsproject.com/forum/thread...tch-chat-with-midi-devices.120911/post-526292
Just signed up to say thanks for this amazing program and to ask a question. Does this support pitch bend events? I doesn't seem to recognize my slider and obs-midi totally ignores those events from what I've seen.
Hi, I'm trying to use a korg Nanocontrol 2 along with voice meter potato AND this software and I'm struggling a lot. Voice meter potato was one click and my board was interacting with it, but whenever I run this program, it just doesn't see the Nanocontrol 2. When I try to add a key bind it doesn't show my midi board being connected at all. What am I doing wrong?
FIXED: You have to install this program AFTER installing loopMidi, then it will work. Now Im having another problem though, I still can't seem to use both this and voicemeter potato at the same time. Any help would be appreciated.
I'm having some issues getting the slider to work on adjusting filters. I'm testing it on native filters using an APC40 MK II. Here I'm trying to adjust the opacity of a chroma key filter, but the slider is not having an effect. I set it to adjust the Desktop Audio and the Slider does adjust that, so I think it's something wrong with my filter configuration. I noticed the filter has multiple drop downs for the same parameter, so I wonder if that may be an issue.
Thanks!
Is this project not open source?
I am interested in using this program, but I would be more comfortable using it if it was open source, but I'm not sure!
Thanks
Its been a while since I've updated this and in the most recent version the stop sound bind seems to crash the program without any crashlogs and I can't fall back to an older version that it might not crash without going back to the previously installed version
Same, I only recently downloaded this awesome plugin. The only problem I've had so far. I wanted to have it just in case I accidently press too many soundboard keys.
Hey! This is an amazing plugin, and I'm currently using an Akai APC40 in conjunction with Twitch, and its been SO clutch.
Question, however. .... This might have been answered, but I cant find it and searching by keyword is a bit difficult for the name of this plugin.
Where are the profiles saved to on Windows 10?
Its a necessity at this point to back up, and restore profiles in case something happens to my machine.
Configuring this from scratch would take forever.
%appdata%\MIDIControl
I cannot for the life of me get this plugin to work with sliders and filter settings.
I'm using the native compressor that comes with OBS. I add the filter to my source. I open this plugin and add a new bind - the plugin detects my Kork NanoKontrol 2 and registers that a slider has been moved. I tick the adjust filter box, select compressor from the first drop down and output gain from the second. I save the bind.
I go to app data and add "compressor_filter.output_gain,0,5.0" to the filterminmax file, save it and close it.
When I move the slider, nothing happens on OBS. Does anybody know where I'm going wrong? The slider works perfectly for the adjust volume option instead of adjust filter.
To add to the above - I'm using non-native plugin called 'Audio Monitor' - The audio monitor filer appears in the 'adjust filter' section first drop down, but there are no settings showing in the second drop down as per below. Any ideas?
Making slow progress. I've now got the plugin to pick up the Audio Monitor settings and adjust them. However, the volume moves in jumps and not as you would expect on a slider i.e. the slider seems to only be able to set one of 3 values depending on its position - 0% volume, 78.73% volume and 100% - There are no inbetween values.
To add to the above - I'm using non-native plugin called 'Audio Monitor' - The audio monitor filer appears in the 'adjust filter' section first drop down, but there are no settings showing in the second drop down as per below. Any ideas?View attachment 76129
could you drop here the link to the non-native plugin ? So I can check (hopefully tomorrow)
@Etuldan had an interesting find. The source I was referring to earlier that was jumping from 0 to 78.3 to 100 was Spotify which is coming in via Virtual Audio Cable as a Mic/Auxiliary device in OBS' global audio settings. I tried a similar bind on Discord which is routed in the same way and it works perfectly for Discord.
I went into the filterminmax CSV file and changed the min max from 0,100 to 0,10. This made the slider work perfectly for Spotify (a smooth slide from 0% to 100%), but capped Discord maximum at 10%.
Will continue investigating
