VinciFlow - Stream Graphics Controller
VinciFlow - Stream Graphics Controller 3.8.0
In the last version I have added a patch that allows you to create and control your own browser source. Just create a blank browser source, click on the refresh button on the dock to reload the available sources then select your source. Since I never used MACOS and the plugin for MACOS is compiled through GitHub workload I couldn't test the plugin, you can join my discord channel and I may be able to guide you https://discord.gg/2yD6B2PTuQ just DM MMLTech
Sorry, I am not a discord user. I did play around a iittle but, but will try it again with your suggestion.
MMLTech updated Smart Lower Thirds with a new update entry:
Version 2.5.0 released with some cool new features
New Features
- Custom Dock Labels: Added a new "Label" field in the Settings dialog. You can now name your Lower Thirds (LTs) specifically for the dock display without affecting the underlying data name.
- Radio Mode (Auto-Exclusive Switching): Added a new checkbox in the dock. When enabled, activating a Lower Third will automatically deactivate any other active LTs, ensuring only one is on-screen at a time.
- Dynamic Browser Source Scaling: Added width and height settings directly to...
Thank You so much for your upgrade today. I found the save and apply button and can edit as I like, but it doesn't show up in the browser anymore. Getting closer.......update: I resized the window and now when I click on it I see my lower thirds. It appears I'm on my way. Thanks!
Sweet, glad you figured it out ! I’m making a nee video to explain the new features because there is a bunch of them lately
This is fantastic! I am getting the hang of it! However, I wonder if you can adjust the size of the fonts, I mean the size of the letters? I don't see it. Is that an option? Thanks.
Thank You! Don't know how. Do I change one of the parameters in the Css edit window?
do the following and adjust it to your needs
I have a small request if possible. It seems like edit window can't be resized easily to get to the bottom right to save and apply. I don't know if it's a Mac thing, my Mac config or if it's something you can change. I always need to hit that green resize button in order to see the save and apply button at the bottom right to save my changes. Worth the effort if it's not on your end. Thanks so much!
That issue will be addressed in the next version, due to so many options in the settings window the window becomes too large overflowing the screen.
Here is a quick preview of version 2.6.0 the settings dialog is fully resizable to fit every screen resolution along other additions and features
Version 2.6.0 is now Released
Smart Lower Thirds – Changelog (Latest Release)
Managed Browser Source Selection
- Added a Browser Source selector in the dock, allowing you to choose exactly which Browser Source instance will display your lower thirds.
- Automatic detection and listing of all available Browser Sources via a combo box.
Advanced Template Lifecycle Hooks
- New awaited lifecycle hooks for custom templates:
• __slt_onShown – called after the...
V2.6.4 Released to adress minor bugs in the main minor version
✨ Summary
This update focuses on visual polish, layout stability, and usability improvements across the Lower Thirds Gallery and Settings UI:
  • Fixed stretched and uneven layouts in all settings panels.
  • Introduced proper top-aligned content behavior inside full-height panels.
  • Redesigned the Lower Thirds Marketplace cards for perfect full-width alignment.
  • Removed unwanted borders and spacing artifacts.
  • Center-aligned call-to-action buttons for a...
