VinciFlow - Stream Graphics Controller
VinciFlow - Stream Graphics Controller 3.8.0
Wow, I have not been able to get this to show up in flatpak version of obs studio. Does it work in that version? It does show in the standard obs studio version but that version of obs does not have the "Browser" selection in sources so Vinci will not know where to go. I wonder why there is not Broswer selection? ?
Hmm I never tested the flatpak version, I'll have to give it a try and see what's wrong with it. Thank you for the heads up !
Thanks, you might call this a work around but i installed the previous smart lower thirds on the flatpak obs studio and it kinda worked. I have to reboot whenever I change colors as it won't show me the drop downs if I want to change to another color. Look forward to your insight. Vinciflow works on my mac M3 and on the standard obs studio non-flatpak version.
I tried to access the website, but it shows me this access error...
Is there a way to turn off the Join discord slider? I don't see it on some of the plugin screenshots rom the website
Hi, Thank You for working hard to update this awesome plugin! One suggestion for your tutorials though. Please include that the browser source needs to be at the top layer in order for it to be seen. It would make sense, but I had created some that I was experimenting with a while ago, so after I upgraded it today I thought it wasn't working. because I couldn't see it. However, I realized that I just couldn't see it because other sources were in front of it. Still, awesome job though. Thanks!
well the plugin already started getting to public so a lot tutorials from other streamers will appear soon :D but I'll take that into consideration on my next tutorials. Thank you :D
MMLTech updated VinciFlow - Stream Graphics Controller with a new update entry:
Add template parameters API, drop StreamRSC
Added support for per-lower-third runtime template parameters and expose SetTemplateParameters/GetTemplateParameters over the vendor websocket. Implemented set_template_parameters/get_template_parameters in core (persist per-LT JSON and update combined parameters file), added declarations and QJson includes, and wired websocket request handlers + request parsing and registration. Updated docs with example websocket payloads.
